Will it work, I need to jump on this deal!
Old Sep 28, 2008 | 12:41 PM
solfish's Avatar
Question Will it work, I need to jump on this deal!
I just found a 2007 2500 Ram that has no engine, trans, tranfercase or radiator.
I have a 1998 12 Valve, auto 4wd.
It had a 6.7 diesel in it stock.
Will mine fit the 2007?
How much time and money do you estimate it costing me?
Old Sep 28, 2008 | 12:59 PM
raymond21's Avatar
I've never done that swap but I've done some crazy stuff. That should be an easy enough swap to do. A 12v in an 07, a lot of folks would like that combo!
It really boils down to your skill level and facilities to work in. I say if the price is right go for it!
Old Sep 28, 2008 | 01:07 PM
solfish's Avatar
Do the 07's have a throttle cable or do they have wires?
Old Sep 28, 2008 | 03:18 PM
solfish's Avatar
Anyone know where I can find engine mount specs for both trucks or an easy way to figure this out. Also have a concern about shift linkage for auto trans.
Old Sep 28, 2008 | 04:15 PM
dozer12216's Avatar
With a donor truck you should be in good shape engine wise. There will be much work involved in electronics. Wiring will be a big issue as have to marry 98 into the later. The tranny from donor should be O"K and you have the linkage. Just have to make it work. You know the title should be revamped to a 1998 salvage if you do this. Value would be low if tried to sell. Not many people will have the intestinal fortitude and understanding to make good on the electronics. So much is ground controlled by central timer module now.
Old Sep 28, 2008 | 05:34 PM
solfish's Avatar
As far as electronics, I don't think my 12 valve or trans has any. I think think the only electronics for my trans is on my throttle linkage. (TPS)
Another thing I was wondering is my transfer case has a lever on the hump to control it. Doesb't the new ones has a switch on the dash.
Seems like a huge job, but it would be the perfect truck, even if it's a salvage title.
Old Sep 28, 2008 | 06:13 PM
rich's Avatar
it will work we did it on my 03 with out a donor truck but it was a stick the gauges will not work nor the a/c with out some engineering the main ecm controls those
Old Sep 28, 2008 | 06:21 PM
19Fury69's Avatar
I say do it, it would be the ultimate truck!!! As for gauges, make your own dash with aftermarket gauges, that would be cool you could probably fit like 10 pillar sized gauges in there(forgot the size) and the tach and speedo.
Old Sep 28, 2008 | 06:57 PM
solfish's Avatar
Rich, How did the engine mounts work for you? Did you have to fabricate them?
I'm mainly concerned with down time. Not to worried about guages and a/c. I can fix them as I go.
Old Sep 28, 2008 | 08:33 PM
rich's Avatar
they had to fabricate the one for the drivers side for sure cant remember about the passenger side, plus the radiator hoses are different. also had to do some fabricating for the powers steering. we didn t have a donor truck tho all we had was the engine.
Old Sep 28, 2008 | 10:15 PM
solfish's Avatar
I can grad as much as I want of my 98, but I don't know how much will swap over. I think the axles are the same, but I don't know about the linkage. Going tomorrow to take measurements and see what I'm getting into.
Old Sep 28, 2008 | 10:25 PM
2500's Avatar
now why in the world would someone want to convert a good title into a salvage title?
I've seen tons of vehicles with engine/tranny swaps all with original titles..
Old Sep 28, 2008 | 10:53 PM
solfish's Avatar
the 07 is a salvage, but I think I can have it inspected to have it cleared.
I can't find a reason not to. especially because it's $8k for the 07 and my 98 is paid off.
Am I missing something with the title deal?
Old Sep 28, 2008 | 11:23 PM
PapeCAT's Avatar
Are you talking about the white '07 for sale in west sacramento by those russian dudes? If so I looked at it a few weeks ago... 0 miles,, no interior, no door panels, dash stuff in the center is ripped up, column is ripped up. Have you seen it yet? other than that the truck is straight save for the drivetrain removal hack job, looks like they ripped it out in a hurry... you'd have to basically just slam your drivetrain in there, and rip the cab down to nothing, and custom build the dash/mech gauges etc. you don't need to 'jump' on it though... the kid was going to combine his '05 with that '07 and put the 5.9 common rail in it,,, would sell both for 17K.... buuuuut even he got discouraged and lost interest. The truck looks cool though.... It is legit, 0 miles or near that for sure.
Old Sep 28, 2008 | 11:38 PM
solfish's Avatar
that's it. Is it that bad
