V10 to cummins swap... questions-
Old Dec 1, 2009 | 11:41 AM
pcgym's Avatar
I am finishing gathering parts to swap my 12V into a V10 truck and wanted to know if the power steering lines were the same. I also wanted to know if I can make use of the drive shaft (my truck was a 2WD 5speed and the V10 is an auto) or will I need to have one made up. I have not seen the V10 truck in person yet and just wanted to be ready when I make the change. I am always grateful for the advice I get here- Thanks
Old Dec 2, 2009 | 08:13 PM
rockcrawler304's Avatar
I'm going to say the PS lines will be different and you will need a new or modified DS. The auto will be a longer trans so you will most likely need to lengthen the DS.
Post pics of the swap as you progress!
Old Dec 17, 2009 | 07:15 AM
cnvrt2cummins's Avatar
we are in the middle of putting 93 5.9 into a 95 v-10. trans stays put but you will probably need to change the governor weights in the trans if you have a 47rh, not sure what you need to do if you have an re. Please use diesel ecm and cluster for the easiest way for your cluster to work.
jaconst
26
Apr 7, 2019 06:52 AM
kX500
May 2, 2010 07:14 PM
mad2smile
May 9, 2007 12:57 PM
johnny5.9
Feb 22, 2007 02:21 PM
dtpatt2
Jan 14, 2005 04:56 PM
