Project SS....Underway
Old Feb 20, 2008 | 10:55 PM
  #31
dieselJon's Avatar
The previous truck doesn't have AC, the old ac from the 350 will be mounted somewhere. But I am waiting for the manifold, and then to put everything in and get it running. Priorities.
Jon
Old Feb 24, 2008 | 08:45 PM
  #32
rbrettctd's Avatar
How comes it?
Old Feb 26, 2008 | 10:12 PM
  #33
dieselJon's Avatar
Not much. been around 0-20* here
Jon
Old Feb 27, 2008 | 09:46 PM
  #34
rbrettctd's Avatar
If you end up down here youll love it....89* monday afternoon, 24* at 5:30 this morning....Gotta love Texas!!!
Old Mar 2, 2008 | 12:36 PM
  #35
dieselJon's Avatar
Well, yesterday, I got the old exhaust system completely off. I set the engine into some new bracket hole to set it lower, went to raise it up to adjust it, and the ram on the hoist wont go up 1 more thing to go wrong. Good thing I have a 2t come-along and a big 12" I-beam to use.
3rd Gen manifold is on its way as of yesterday. Thanks sliqwil!
Jon
Old Mar 27, 2008 | 04:26 PM
  #36
dieselJon's Avatar
Talking
I do not know what happen to my last post but I got the 3rd gen manifold on and it fits. I ported it a little to match the old square exhaust ports.
Well, Saturday I put the front crank seal on. No more leaks hopefully. I started cutting up the front clip to hold the stock 93 Dodge radiator. Fits nicely now. I tried to take the radiator fan off but it wasn't budging with a 12 or 14" crescent wrench.
Monday I finished the cutting of the front clip. Set it in place and went to O'Reillys after work to get a fan clutch wrench repair set thingy...Whatever it is called. I heated the nut up and was turning it CW. Nothing. Kept slipping the wrench off and busting my knuckles. I was using a 20oz hammer too! Well here comes my bro from work and looks at what I am doing. He asks if I tried using the 3" exhaust pipe that is about 5ft long There it goes, 2 hrs of busting knuckles and in 30 secs it was off.
Well, as I was doing this, I found the right wire and used the battery to connect directly to the old in-tank fuel pump for the TBI 350. I drained all 15 gallons of gas and gave it to my parents. They needed it and paid for rent a bit.
Ok, I got the belt on, some wires connected. I put in 3 gallons of oil. I thought that since it sat for about 9 months, I could turn it over with out it firing up. So it goes crank....crank.....VRRROOOMMM!!!!! I was like Crap! I forgot the IP held some fuel! No turbo, no exhaust, just the manifold. LOUD! I jump out and pull the shut down lever. Whew! Nothing broke.
So now, the chevy fuel pump goes into the LP a about 10 psi and I also used the stock chevy return line. All I have to do now is get the bolts for the torque converter tightened, turbo on, IC on, fill the radiator, figure driveshaft lenghts and get my dash wired up. You know the the Equus gauges that you buy at parts stores fit nicely into the old dash and gives it a classy look for pennies on the dollar? http://www.iequus.com/product_info.p...ory_id=100_110 Now the 3 gauge pod set is going to hold the Boost, tranny temp, and oil temp gauges. The pyro goes where the optional analog clock would go on the dash. I will get a pic soon
That is what is going on now.
Jon
Old Apr 1, 2008 | 05:38 PM
  #37
rbrettctd's Avatar
Sounds very nice! Great progress!
Old Apr 5, 2008 | 06:05 PM
  #38
93Fury's Avatar
If you are looking, I have a Steel 2" cowl induction hood for sale off my Suburban. Post some pics man.
Old Apr 8, 2008 | 02:07 PM
  #39
dieselJon's Avatar
We are having computer problems here. I lost quite a few pics that I took. The hard drive crashed
Old Apr 22, 2008 | 09:32 PM
  #40
rbrettctd's Avatar
ARe you alive??????
Old Apr 26, 2008 | 02:58 PM
  #41
dieselJon's Avatar
BUSY!!! We have had computer crashes, down internet (wireless), new GF, planning for a addition on my parents house, dealing with my druggy cousins kids and trying to show them how to really live as their mom "tries" to get her life back together. GRRR! But the D70 rear is going in as soon as I get the oxy/acetylene tanks to help with the nuts on the U-bolts. It is in and running, just need to swap the rear-ends and get the drive shafts done.
Jon
Old Apr 29, 2008 | 06:45 PM
  #42
dieselJon's Avatar
I got the D70U under the Burb now The D70 spring mounts are in the exact location for the springs on the Burb. I am stoked!
Pics coming very soon.
Old May 27, 2008 | 08:23 PM
  #43
jjdiesel1990's Avatar
So how is this coming along?!?!
Old May 29, 2008 | 05:34 PM
  #44
rbrettctd's Avatar
I too wanna see!!!
Old May 31, 2008 | 11:36 AM
  #45
dieselJon's Avatar
Lemme take some pics today and upload them to the photobucket account.
The driveshaft from the 93 Ext cab 4x4 250 is about 4" too long. I got everything else pretty much done....Well, the major stuff All the little minor stuff is coming soon
Jon
