Old Power Wagon Body?
Old Apr 22, 2009 | 12:16 AM
smallwwb's Avatar
I'd like to put an old power wagon body on my diesel 4x4. How hard would it be to do the conversion? I'm looking at the M37- style '46-60's body style.
Dieselpunked.
Old Apr 22, 2009 | 12:22 AM
Crazy Matt's Avatar
Its doable. Hood was lengthened on every conversion I've seen tho.
Might also concider the 60's power wagon like mine. I saw one for sale awhile back. It was a 70? on a 95 chassis. Looked pretty good in the pics. Lot more engine bay room for a ic then a early truck.
Old Apr 22, 2009 | 08:30 AM
smallwwb's Avatar
Question
Do you have any links or photos of the conversions you have seen?
Old Apr 22, 2009 | 09:26 AM
schamran's Avatar
That would be pretty cool. see if you can keep the same cab and swap out the front fenders and the bed. I think the cabs are pretty much the same, and this way you wouldn't have such a wiring nightmare. I am not sure if this will work tho.
Old Apr 22, 2009 | 09:29 AM
schamran's Avatar
Trooperthorn might know.
Old Apr 22, 2009 | 09:52 AM
Crazy Matt's Avatar
The 2 old body ones were in person. and the 70ish one was on sweptline.org about a year or so ago.
Id have to look for it
Old Apr 22, 2009 | 10:29 AM
Cujo_07's Avatar
Here's one on ebay
http://cgi.ebay.com/ebaymotors/1949-...3A1|240%3A1318
Old Apr 22, 2009 | 03:42 PM
schamran's Avatar
Oh, I was assuming you wanted to go with the newer Powerwagon bodystyle. That truck on ebay looks like a 2nd gen, judging by the coil springs in front, and its a 24 valve.
Old Apr 29, 2009 | 08:21 PM
Old-stuff's Avatar
I'm putting a M37 body onto a 90, 4x4, w/CTD.
First thing you do is locate the radiator to center the front fenders over the wheels. Then I had to move the engine back 8" to get the fan to clear the radiator. Not that much trouble. You Will need new driveshaft lenghts. I positioned the cab to clear the engine without cutting into the firewall and extended the cowl to be able to use a stock hood. Make new cab mounts. Then I cut 12" out of the frame to get the rear wheels to match the M37 rear fender location. (the 90 was a standard cab, 8' box. M37s are 6 1/2' box)
The biggest problem for some.The M37 body ends up being about 6" higher than a stock M37 because of the late model frames shape.Some people will like the height, some won't. If you're talking about a civilian pw then all bets are off. The main issue is that the Cummins is about 6" longer than the flathead six. You need to account for that somewhere.
Hope this helps
Ray
Dodgezilla
Nov 6, 2011 04:13 AM
chariotdriver
Oct 18, 2008 10:50 PM
johnny1509
Jul 21, 2004 05:40 AM
Posm
Jul 19, 2004 10:12 AM
Berak
15
Jun 18, 2004 09:49 PM
