Excursion 12v 47rh swap
Old May 24, 2012 | 09:50 AM
tommyfulano's Avatar
Hi guys this is my first post I have been reading this forum for some time now. Im getting some money to start my project and i have some questions and I know that there other posts around that talk about excursions swaps but none talk about a12v with a 47rh. Without that said.
What kind of trans mount adaptation I have to do with a 47rh?
What would better to get a v10 or 7.3L diesel excursion?
Its going to be 4x4. Do I have to switch the input on the t case?
If I get the 7.3L would I be able to use intercooler and trans cooler?
With a 12v what kind of electronics im looking to make the ford dash work?
Thanks for all your help all your comments would be really appreciated
Sent from my DROID BIONIC
Old Jul 7, 2012 | 10:38 PM
hi guys im back finally got my truck yes a truck i know i started this as an ex in mind but i found this 01 f250 7.3 diesel 4x4 in better conditions and cheaper.
with that said my next question for all u 12v racing experts im trying to build my motor from my 94 2500 donor truck which has 220k miles the motor is in really good contions i got the truck from my buddys dad that he had it since 60k miles.
I want to buy a good rebuild kit and some nice pistons and get like a 4k gsk with the hd valve springs and a lift pump also some injectors and a 66mm turbo.
my goal is to be aroud 500-600 HP i would be super happy
Also behind that im planing on building the 47RH with a full rebuild kit from suncoast and a billet triple clutch tc.
Also where should i buy my conversion parts since im not using ford trans i only want like the ac hoses and motor mounts and the np273 input tach kit alternator etc..
With that said i would like some input and opinions and all of them would be gratefully appreciated.
this is the rebuild kit i found
http://www.puredieselpower.com/catal...t-p-28791.html
Old Apr 13, 2014 | 09:23 PM
heykw's Avatar
Did you make any progress on your swap?
5.9Excursion
Cummins Conversions
442
Dec 22, 2014 12:10 PM
crazyjunk99
Cummins Conversions
Oct 9, 2013 07:12 PM
LOP223
Cummins Conversions
Oct 31, 2011 04:59 PM
Fireman438
Cummins Conversions
17
Dec 29, 2008 07:39 PM
LOP223
Cummins Conversions
Mar 31, 2008 11:28 PM
