anyone running a dodge auto in super duty
I'll ask the question this way and see if I can get an answer
If so, how did you make the ford shift cable work on the dodge tranny?
any and all help will be appreciated
lewis
lewis
hi , i used a ford 4r100 cable bracket and drilled a hole then used a bolt , some trimming might be needed ,i dont remember , you need a larger radius lever on the transmission or weld something to make it longer , so the gears match the reading in the cluster ,also you will need to borrow the nipple from a ford auto tranny and weld it to your trans lever if you have an older than 03 trans , i have a 07 cummins with its original trans in a 03 excursion.
heres a pic from cumminsswap.com
Common
05-08-2010 01:06 AM
TireHauler04
Competition / Pulls / OffRoad
28
02-14-2006 11:10 AM
FMB
09-05-2005 01:44 PM
Mexstan
22
06-08-2003 03:26 PM
