4BT Cherokee
Old Jan 31, 2010 | 07:57 AM
torqmonster's Avatar
4BT Cherokee
I have a 90 Jeep Cherokee, just blew the motor last weekend. I'm kickin around the idea of droppin a 4BT in it, anyone put one in a cherokee?
Old Jan 31, 2010 | 08:39 AM
Hodge's Avatar
Hmm... I've never seen one. But, perhaps you could do a seach on youtube. If there is such a beast, then somebody has probably videoed it.
I would have to wonder how the unibody would hold up to the weight and torque. But, I saw a video of a cherokee with a strong running 350, turning some serious numbers on the track, so if it holds that, a 4bt may be fine...
Old Jan 31, 2010 | 08:54 AM
jesussaves's Avatar
where do people get 4BTS??
Old Jan 31, 2010 | 11:28 AM
STate's Avatar
I have seen a couple 4bts for sale on C's List.
...in regards to the 4bt in the cherokee, I would think a dana 44 swap in the front would be in order. The stock dana 30s have a hard enough time with the 4.0L and a set of 33s.
Old Jan 31, 2010 | 12:46 PM
Hodge's Avatar
A lot of Frito trucks and bread trucks ran them. A contractor that I work for has one in a forklift. They are around. Some have turbos, and others don't.
Look around on the Quadratrac forum. Lots of info on 4bt's in jeeps, there.
Old Jan 31, 2010 | 01:11 PM
12valve@heart's Avatar
Do a search at http://www.4btswaps.com/forum/index.php
If someone's done it, it's probably on there.
Old Feb 1, 2010 | 01:09 PM
apwatson50's Avatar
I did some measuring on mine a while back , and came to the conclusion that ~10in of lift would be needed to be able to close the hood, and clear the oil pan with the axle.
Old Feb 2, 2010 | 09:44 PM
BigBluemotors's Avatar
Torqmonster,
In addition, you would need to cut the firewall or modify the front end to allow for length. Also the front end may have to be beefed up since I believe the BT3.9 weighs more than the 4.0 gasser.
I am slowly working on a Cummins B3.3 1990 Cherokee conversion. I still had to install a lift to clear the front axle. I am awaiting better weather to finish the front end and manufacture motor mounts.
I am not saying the BT3.9 can't be done, but it is more work.
Chris
AKA:BigBlue
Old Feb 3, 2010 | 01:28 PM
Goofball's Avatar
I remember seeing a vid on youtube of a 4b in a comanche so it can be done
G1625S
Feb 21, 2005 05:29 PM
willysrule
Feb 11, 2005 12:39 PM
iwantaCUMMINS
Jun 1, 2004 07:32 AM
