1st Gen 4 door Project w/ Pics
Those look great. I kinda wish I had not sold mine. I milled my own with a carbide flush-trim bit with a top bearing in my router. The bearing rides the shoulder on the backside of the hole. I didn't even take the tires off.
bruiser did everything pretty much bolt in drivetrain wise got my 90 then started looking it over yesterday turns out theres bondo in the cab corners needs a door n fenders thinking of a four door swap myself.
yes pretty much everything bolted right up minus the transmission mount. I had to fab a new mount for mine and I know others have had to do the same.
Count on making custom Driveshaft and modifying the carrier bearing support or crossmember. You will also drill two wholes in the frame to bolt in the skid plate. Other than that fairly bolt up. Fenders and firewall will be drilled for various stuff.
I did have to modify rear section of driveshaft
I used a carrier bearing and front shaft out of a second gen. I unbolted the mounting plate and moved it to the bottom of crossmember. The carrier bearing from the second gen sat a little higher and made a positive angle coming out of the t case. I will let you all know if this works out going down the road.
Mine is cobbled together...as well as my tranny mount. I really want to get things back to the way they should be.
fuel tank
on my 92 dodge diesel.i dropped tank the clean it.well i put back up all together.now my fuel gauge does not work.it bouncing around and sometimes it just says E.need help thank yall
my guess would be loose wires out side of tank or sending unit inside tank came loose and is not working correct.
Bruiser, do you know if the stock motor mounts and mount location for the 84 360 gasser will work for a CTD swap? Or will I have to relocate the brackets. It has the correct 5spd for the swap. And do you know if the cummins has a bigger flywheel or not? And would the PTO on the trans hinder anything?
my PTO area was wide open on my swap
