12 valve in 03 common rail up and runing
I've got my gauges working and charging all good but i cant figure out the power steering. Does anybody know how to make it work? Any help would be great. Thanks
I don't have a 3rd gen FSM to look at, but I am fairly certain it is the same hose routing as the 97 was........
What is it not doing, just no assist?
Did you raise the front end off the ground and while running, run it lock to lock to bleed all the air out?
Yep, tied together. Many times when you replace the pump it is a pain to get the air out, hence the suggestion to get the front wheels off the ground and turn lock to lock. Makes it much easier to get the air out. Even then sometimes it takes quite a bit of turning.
https://www.dieseltruckresource.com/...got-em-169715/
No it fits fine, u have to move the motor mounts back in order to clear tohe oil pan. But its not to bad at all i kept the computer and harness and used the tone ring from the common rail built a bracket for the sensor and that will let ur tach work which will charge ur battery.
