Wish Me Luck
Old Mar 11, 2006 | 09:01 PM
Forrest Nearing's Avatar
AC has no impact at WOTI'm assuming you've got an automatic? that thing is soaking up TONS of power/torque
Old Mar 11, 2006 | 11:21 PM
displacedtexan's Avatar
He has an auto that is barely clinging to life. I thought it was gonna give up the ghost a long time ago.
Congrats on the run. If you had a good tranny, you would have cracked 400 easy. So what do you think you will put on the rolers with the new DTT?
Old Mar 12, 2006 | 10:46 AM
BigBlue's Avatar
I was hoping for 403hp cause my buddy put down 402. As soon as the new tranny goes in I'll have it dynoed. I'm hoping to be well over 400. Maybe 420 or so.
Doug I dynoed on 5x5. There wasn't enough time to play around with the comp to much. When I get home I'll post the dyno sheet up and yall can take a look and let me know what yall think.
Forrest, does the AC turn off at WOT like a lot of other cars?
I'm just so proud of my tranny. When I left I put it on 5x5 and stomped on it from a stop and it spun the tires. First time it's ever done that. I think I'll give it a bath today to thank it.
Old Mar 12, 2006 | 10:53 PM
BigBlue's Avatar
http://www.putfile.com/bgbldodge There's a couple of vids and my dyno graph.
Old Mar 13, 2006 | 09:16 AM
signature600's Avatar
Way to go Blue!!!
Beat me
Our next dyno is April 8th, my tranny's fine, btw
I'm with these guys, though! Fix that tranny, and you're over 420 What boost are you running? Do you have RJ's wastegate?
Chris
Old Mar 13, 2006 | 04:29 PM
mikmaze's Avatar
shoulda put some weight n the bed for traction on the rollers....
Old Mar 13, 2006 | 09:44 PM
BigBlue's Avatar
Speaking of traction, after the dyno I checked my air pressure and one of my back tires was at 30psi and the other at 15. One of my fronts wa also at 30 and the other was at 55. Gotta love discount tire.
sig, I've got it gated to 40psi but I don't think I was quite hitting it. It took forever to spool my turbo up on the dyno. And yes I'm running RJ's old wastegate.
Old Mar 14, 2006 | 12:14 AM
cumminsdriver635's Avatar
IMO if your converter isnt slipping in your tranny, then you are putting down the same amoutn of power as an aftermarket tranny as long as you are running with the converter locked. Good #'s none the less
Eric
Old Mar 14, 2006 | 12:29 AM
BigBlue's Avatar
As far as I know the converter ain't slipping in lock up. There's no RPM surge or shuddering. Wish I could say the same out of lock up.
Old Mar 15, 2006 | 10:56 AM
Mike D's Avatar
Eric
My thoughts exactly.
babyray55
Jul 2, 2011 02:43 PM
Homestead
ABDTR #5
19
Jan 31, 2009 11:52 AM
ratlratl
Nov 9, 2008 10:37 PM
Dodgezilla
47
Feb 22, 2008 10:02 AM
cameroneod
16
Oct 5, 2007 12:36 PM
