what should i run in the quarter
Old Jan 8, 2007 | 12:51 AM
curts99's Avatar
ive got an edge comp wire tapped,boost elbow,stage four edge jammer nozzles,4 inch straight pipe, 4.10 gears, built auto w/pressure loc and 3 disc billet torque converter, planning leaving in 2wd and running a 27x12.50 slick
Old Jan 8, 2007 | 02:42 AM
BigBlue's Avatar
Why run 2wd on slicks? Why not do a 4wd launch on your 35's? Just curious. I'm thinking you should be knocking on something in the 14's if you launch it good.
Old Jan 8, 2007 | 08:15 AM
one54ton's Avatar
With nearly the same setep and a stock trans with like a 15lbs 4wd lauch I ran a 14.9.
Old Jan 8, 2007 | 10:08 AM
curts99's Avatar
dont got billet input or output shafts and dont got the money to fix it it something breakes figured play it safe
Old Jan 8, 2007 | 06:53 PM
John_P's Avatar
curts99:
I would say you should be in the mid to high 14's. Be careful you don't get to high with the boost at the staging lanes!! FWIW, I would not go over 10lbs.!
Why? Because I broke three (3) output shafts on my 2002 doing that!
Good luck!
John_P
Old Jan 8, 2007 | 07:35 PM
curts99's Avatar
leaving in 4 hi or 2wd with the slicks? what would be the safest you think 2wd i think the slicks augh to hold with some boost
Old Jan 8, 2007 | 08:18 PM
runamuk's Avatar
2wheel drive will leave much slower than 4x4. It would, however, no doubt, be less strain on the transmission output shaft.
4x4 launch will definetly give you the best track time.
I'd say 15.5 for your first pass and improve on that.
I want slicks for my kids truck.............
Rick
Old Jan 8, 2007 | 11:01 PM
curts99's Avatar
yea i was thinking in the mid to low 15's
Old Jan 8, 2007 | 11:10 PM
Tate's Avatar
You'd be running out of RPM's in the top end with a 27" slick, methinks. Your truck starts defueling at 2700 rpm (unless you have something else thats not in your sig), which would be around 89 mph.
Old Jan 8, 2007 | 11:30 PM
curts99's Avatar
i was thinking the 27 would be a little short but they are free may as well try em
Old Jan 9, 2007 | 12:16 AM
cumminsdriver635's Avatar
I run a 15.12@85 on stock shafts with stock injectors and delivery valves in my 12 valve. You should surely be in the 14's. I leave with 8-10psi and run in 4wd. Actually I think I could run a high 14 now.
Eric
Old Jan 9, 2007 | 12:50 AM
runamuk's Avatar
curts99,
We can fix the 2700 governor springs with a 3200 spring kit in my garage You will have to buy the kit. I can also give you a custom ground fuel plate that will work!
I want those slicks!!
Rick
Old Jan 9, 2007 | 12:59 AM
curts99's Avatar
they actually roundy roundy slicks gotta get em hott as can be but they work hopefully i can put a fuel plate on my truck and springs?
Old Jan 9, 2007 | 01:00 AM
You cant put a plate and governor springs in a VP44
Eric
Old Jan 9, 2007 | 03:03 AM
runamuk's Avatar
DOH! Yep not a 12v sorry! I can however help you out with a boost elbow and a hot rod VP!
Rick
