What Gear To Dyno In ??
Old Jan 6, 2008 | 02:55 PM
Ghost Ram's Avatar
I am going to the dyno soon but have never dynoed an auto trans or a diesel truck. what gear am i going to want to make pulls in and w/ tow/haul on or off? remember i have the 06' w/ the newer tow/haul feater seperate from overdrive off.
Old Jan 6, 2008 | 03:20 PM
N.Johnson's Avatar
OD off, Selector in drive. When convertor locks in third gear, around 46-48 mph give her the skinny pedal. Don't mash it gently press to floor so it doesn't downshift.
Old Jan 6, 2008 | 04:25 PM
ctd89-99's Avatar
I don't know anything about the tow/haul, but you want to dyno with the overdrive on and converter locked. Thanks Steve B.
Old Jan 6, 2008 | 07:15 PM
Ghost Ram's Avatar
ok, two different responses. thanks for the help, both seem like they would work.
i can understand the 3rd gear pull w/ od off because it will stay in 3rd and wont upshift correct?
and i have heard that alot of dyno operaters make pulls in od.
so what is the correct way to do it? btw, this will be done on a mustang dyno w/ load applied.
Old Jan 7, 2008 | 09:21 AM
ctd89-99's Avatar
Dyno in Overdrive with the Torque Converter Locked. No matter what type of Dyno I've dynoed on this is the way its done. Thanks Steve B.
Old Jan 7, 2008 | 10:16 AM
Ghost Ram's Avatar
sounds good to me. im not very familiar w/ auto trannys, at ehat speen or rpm in od does the tc lock up? i have an 06 48re, Thanks.
soon i will be shooting for some low 12 high 11 sec ets of my own. drag racing has always been in my blood, just not in the form of diesel trucks i am learning as i go.
does anyone offer any type of piggyback or standalone tunning hardware/software to make changes in the ecm w/ a laptop while on the dyno or at the track to create your own fuel mapping?
Old Jan 8, 2008 | 01:39 PM
RowJ's Avatar
Originally Posted by Ghost Ram
....and i have heard that alot of dyno operaters make pulls in od. so what is the correct way to do it?
I disagree with Steve B.
Dynojets should be dynoed in OD.
Loaded Dynos, like the Mustang, work best in third with OD locked out. You want as close as possible to 1:1 gearing for a loaded dyno.
Your operator should know this and advise you accordingly.
RJ
Old Jan 10, 2008 | 08:52 AM
PourinDiesel's Avatar
Dynojet/inertia=OD (5th gear in a 5 speed, 6 gear in a 6 speed)
Mustang/Load type=Direct (ie Tow-haul, OD off, 5th gear in a 6 speed, 4th gear in a 5 speed)
Old Jan 10, 2008 | 10:08 AM
jlibert's Avatar
how about a dynojet with a load cell? 5th in a 6spd or 6th?
Old Jan 10, 2008 | 10:12 AM
Load is load...(however inquire with the operator to be sure).
5th gear in a 6 speed.
Old Jan 10, 2008 | 10:23 AM
RowJ's Avatar
Is this a new Dynojet model.... or do you refer to the Drum Brake. if it's just the brake...stay with top gear!
RJ
Old Jan 10, 2008 | 12:10 PM
Ghost Ram's Avatar
ok, see if i got this right....
w/ my 48re auto, on a dynojet i want to be in od. on a mustang i want to have tow/haul on and od locked out. correct?
Old Jan 10, 2008 | 12:40 PM
jlibert's Avatar
RJ
not a dyno expert by any means, but I don't think it's a drum brake. It's an eddy-current load cell.
John_P
NCDTR #18
22
Jul 10, 2008 07:01 PM
John_P
NCDTR #18
55
Apr 12, 2008 03:56 PM
Dean Snow
Nov 8, 2007 03:26 PM
pwerwagn
Feb 28, 2007 03:18 AM
502502
23
Nov 23, 2005 06:16 PM
