sled pulling gear choice question
Old Mar 7, 2007 | 12:02 PM
getblown5.9's Avatar
out of curiosity...what advantage is pulling in 4th-4 low over 2nd-4hi????
4th-4low has a ratio of (1.39x2.72) or about 3.78
and using 2nd-4hi has a ratio of (3.38x1) or 3.38
I thought the lower ratio for more wheel speed would be better? is the higher ratio easier on the drivetrain. im just curious looking for an explanation
Old Mar 7, 2007 | 01:27 PM
PourinDiesel's Avatar
2nd gear hi range will give you more wheel speed and be a little easier on the drivetrain.
4th lo is good for a heavier sled and will help keep your motor lit but not enough wheel speed to usually be competitive if you are limited by rpm's (like under 3600).
All the video's in my sig are 2nd gear hi range except for the last one.
Old Mar 7, 2007 | 01:44 PM
well im running the range of about 570hp now do you think it will benefit me to stay in 2nd and high then?
my vp44 limits me to about 3400 and then it dies off really bad.
Old Mar 7, 2007 | 02:10 PM
For that power 2nd gear hi is a good gear as long as your running 33's or 35's or smaller.
Old Mar 7, 2007 | 02:35 PM
35's , 3.54 gears
i guess ill find out how it works if i ever get to hook to a sled
Old Mar 7, 2007 | 02:48 PM
Redline Ram's Avatar
also depends on the track conditions.
Old Mar 7, 2007 | 06:53 PM
59Dsul's Avatar
35's, 3.54's,and 2nd high on a 6-speed equals quite a bit of gear if the sled's heavy or the track is tight. I've got a spreadsheet I downloaded from a TDR member that shows speeds based on transmission, rpm limit, tire size, and gears. In 2nd high, you're at almost 29mph at 3400. In 4th low, you're at almost 26mph (assuming a 35" tire is actually 34"). If there's not a huge amount of competition in your area, 4th low will go a long way ....
andy
Old Mar 7, 2007 | 07:44 PM
LUKE-MM-PULLER's Avatar
I only have a 5sp but I pulled in Hi 1st then I tried Low 2nd, I went a lot farther in low range cause i was able to keep the rpms up. but my truck was completely stock the last time I pulled it. It'll be interesting to see what it does this years with the mods I put on it. Good Luck !
Old Mar 8, 2007 | 07:30 PM
GO 4LO's Avatar
4th lo is going to be a heck of a lot nicer to your tcase than 2nd hi will...
Chris
Old Mar 8, 2007 | 08:38 PM
SmokinDodge12V's Avatar
Chris
Ive seen alot more transfercases broken in low range than hi range.
Old Mar 8, 2007 | 09:02 PM
i have proof!
Old Mar 8, 2007 | 10:24 PM
jd4440's Avatar
gear
i would definetly try 2nd high but i also pulled against i guy with 37 in 4th low and 3.55 but i beet him in 3rd low with a 5 speed and 3.55 with 33's and he had jammer 5's and a edge comp but it was only a foot i beet him by also rare track conditions rainy
coreydr2003
MODTR #30
27
Oct 1, 2009 04:56 PM
andy2
Jan 17, 2008 04:49 PM
rockjeep73
Competition / Pulls / OffRoad
Jul 24, 2006 09:30 PM
squirlchasr919
May 4, 2006 07:52 AM
deezulsmoke
Sep 23, 2005 11:54 PM
