pulling truck
Old Sep 11, 2007 | 10:21 AM
kinser5mfan's Avatar
pulling truck
my nephew just found a 1st gen reg cab 4x4 farm truck needing tranny work
i was hoping it had 4:10's under it but it has 3:56's
the auto trans has no reverse and you have to shut it off to get it back into low gear after it shifts
we were thinking of buying this and starting to build a pulling truck( my check book just sobbed)
this thing goes good in the pasture but like i said it has a ton of tranny issues.
what do you think of pulling with the higher gears? should we keep looking for lower gears before hooking?
the big kicker we can get this running 12v for 350.00
Old Sep 11, 2007 | 10:26 AM
satburn's Avatar
gears will depend a lot on what tranny you stick behind it... are you going manual or staying auto?
Old Sep 11, 2007 | 10:29 AM
i think i would rather have a manual but will have to keep the auto for now
i just spoke with a friend whos dad has a tranny shop, he said we could fix it for now but really need to spend some fat cash if i keep it a auto
any suggestions?
Old Sep 11, 2007 | 10:47 AM
cbtumedic's Avatar
Run (and pm me with the location of it) lol, sounds like a good basis, gears are relatively cheap, also if you check around you could probably find a 727tf for not a whole lot of money and have it built a for a lot less than the 518 that is probably in it. All in all if it's a running 12 valver then the engine alone is worth many times more than the purchase price.
Old Sep 11, 2007 | 11:00 AM
satburn's Avatar
"They" say a final of 15 is good.
Here, play with numbers...
http://www.grimmjeeper.com/gears.html
Old Sep 11, 2007 | 11:18 AM
06 DIESEL's Avatar
If you do not want it let me know I will have a truck and trailer there within a day to pick it up. That is exactly what I have been looking for.
Old Sep 11, 2007 | 11:40 AM
CNeubauer's Avatar
Around here at least I think the auto's tend to be more consistant pullers and most of the time I'd say they have an advantage over a manual. The auto's will let you build up alot of speed early and then you can downshift as the sled get heavy towards the end of the track. If you have enough power I think the 3.56 gears will work but they are going to put more stress on the rest of the drivetrain.
Old Sep 11, 2007 | 12:20 PM
JDGnut's Avatar
If you want to check out the differances.. here's a thread that has some of the ratios listed.. I started it.. but someone added the R&P info...
The 205 T-Case in the 1st gen's is gear a fair amount faster than the case in the 2-3rd gens...
https://www.dieseltruckresource.com/...d.php?t=161352
Old Sep 11, 2007 | 12:55 PM
JD730's Avatar
Here's video of my truck that another member here took. Does 4th and 5th place at local to me pulls, came in 8th in the 1st heat at that one.
My 93 pulling at the Buck
You don't want to know what kind of $$$ is in the trans.
Old Sep 11, 2007 | 02:04 PM
LOGAN's Avatar
Muted User
if you swap to a 727 go with a full manual valvebody. if it dont bounce your head off the back glass when it shifts it aint tight enough. GOOD LUCK finding a company that even offers parts for it though......I called Jegs and TCI, Jegs dont even list anything, TCI dosent even have a core, you will have to send them your tranny and they will build it with no converter for $2200. but you can buy a full TCI street fighter for a big block with no converter for $900.......someones getting screwed and i think its daddy.......gotta love when you slap diesel on something and the price more than doubles........
personally id just through a NV4500 behind it with a twin disk and be done with it. i realize now i wont be building an automatic.
Old Sep 11, 2007 | 02:37 PM
JD730's Avatar
$2200, holy smokes, did you tell them they're smoking something and its not #2. I just looked at Goerend's price list and the standard transmission with a torque converter is $3250 and thats an overdrive lockup unit, the only problem is finding a core to send back to him.
Old Sep 11, 2007 | 03:15 PM
just handed the man some money!!!!!!!!!!!!!!!!!!!!!!!!!!!!
our friend will rebuild it with some leftover stuff for about 150.00 just to get it goin. then over the winterhe says he will build me a good trans. i'm hoping to get in a late pull somewhere in mo,ia,ne late this fall as a farm stock or stock class then do some work this winter including a new trans. the other friend who works for cummins said he has some tricks to add to the motor as we go along and maybe in a few years i will have a "hot" truck to do some serious pulling with. but for now i just wanna pull for fun! ( like that will last)
Old Sep 11, 2007 | 03:38 PM
satburn's Avatar
If it was me, get to wrenchin' and go to this:
http://www.westcentraliowapullers.com/schedule.html
Old Sep 12, 2007 | 11:22 AM
sweet thats only an hour or so from my house!!
HOW EVER....... i told the wife when she got home last night
apparently " do what ever you want" didn't mean what i thought
she was not happy to say the least BUT.. didn't say i had to stop
Old Sep 12, 2007 | 01:40 PM
satburn's Avatar
Now don't go blamin' me on this. I can hear you now. But Honey! I just found out about it today online, it's Satburn's fault for not telling me sooner!!!
I get enough trouble on my own, I dang sure don't need your wife calling me too
