Pulling with nitrous
#31
Test
I know my MLS is on borrowed time,but it's put up a great fight,and as for the Flames out from under my truck,which I have lots of witnesses,I think alot of it's due to the fact the cam in these CR are Extremely retarded!!!! But if you anywhere near ALABAMA,Come by and I'll but on a fireworks show!!!!!
#33
DTR Advertiser
Originally posted by Jetpilot
Well I wish I still had the pic of the 5" SS flexpipe that was pretty much shedded like a slinky when mine went bang one day.....
WhiteSport600,
Diesels do have vacuum. The cylinder pressures are also much higher running nitrous, thus the need for o-ringed head. Some of the guys running the MLS gasket are having better luck with headgasket integrity but they still are failing. Using o-rings/firerings and studs are really necessary for guys who want reliability. If someone doesn't care whenwhere their headgasket lets go then I say go ahead and run nitrous without the headwork. But, if you want to drive to and from the track/dyno without the probability of failure then I would recommend making the proper mods.
My first time I played with nitrous in early 2000 I was able to make 5 dyno runs before the headgasket went. Once it was o-ringed I was able to push the motor over 760 RWHP and I drove it all over the country to race. In 2003 I installed nitrous on a 2001.5 truck and made over 900 uncorrected RWHP, but even with studs and an o-ringed head I blew the headgasket! Yes these trucks were extreme but I have seen a headgasket blow with a resonable boost level, wastegated and a really small shot, you just never know.
Doug
WhiteSport600,
Doug
Don~
#35
i was @ t/s performance while back looking at there race truck says hes pushing 400 shot on it , they were @ the trac the other day and had a backfire and it shook the ground butt he just backed it up and ran again
#36
If you don't belive in backfires go over to the TDR and find HOSS's post on needing a new exhaust system and some body work done to his truck. His stacks are now orbiting the planet.....
There are probably posts on NWBombers about this too. Heck there might be a post on here about it, but I have not looked.
Mike D
87
04-10-2008 03:18 PM
mullercarl
Competition / Pulls / OffRoad
45
03-19-2007 10:10 AM
KatDiesel
10-15-2003 08:09 PM
kingofdodge7131
12-09-2002 06:12 AM
