Pulling Newb
Old Nov 15, 2007 | 12:52 PM
1BAD4X4's Avatar
Pulling Newb
If a guy wants to get started into pulling, running beginner/lower hp level classes... what is done to pulling trucks to get them prepared for it? I know of some thing from reading articles in diesel power and what not... but I'd like to see what you guys say, b/c I know we've got some pullers on this board.
Old Nov 15, 2007 | 06:33 PM
35" 05''s Avatar
1. TRANNY 2. ladder bars 3. find out what power adders are legal in the class u want to be in 4. rear blocks 5. weight rack 6. more power 7. spare parts
Old Nov 15, 2007 | 08:05 PM
The Tank's Avatar
You need HP and $$$$$$$$$$
Old Nov 15, 2007 | 08:11 PM
rustyshakelford's Avatar
im not totally in love with the idea of getting ideas from some of the mags. a good portion of the articles i have read are dumb...filled with bad information and singing the praises for bad products. i take just about every article with a grain of salt. it is nice to see alot of guys trucks from here getting published but if your wanting real info you did right by searching for answers here.
like previously mentioned...
gauges
tranny/clutch
fuel sys
programmers/box
ladder bars
turbo
the list could go on and on
brett
Old Nov 16, 2007 | 04:30 AM
1BAD4X4's Avatar
I was more so meaning like wieght racks/hitches and suspension. Its obvious that a tranny and gauges are needed, hell we need those on a stock truck.
Are there companies/shops making wieght racks and hitches or are these custom made?
Pretty much if I wanted to take a stock truck into a pull... what would be needed at most pulls(since not all pulling associations rules will be the same) to hook up. Oh and I've had a hard time finding ladder bars for anything but a 6" lift... I'll have a 3" when its all said and done. Any reccomendations there?
Old Nov 17, 2007 | 08:16 PM
JDGnut's Avatar
Most places require you to have a 3in opening on the hitch.. for the hook... other places will allow you to block it solid.. or have 1in of travel.. I'd build blocks that you can adjust... Most lower classes do not let you hang weights or at least on the front... (some areas don't have any rules..) We have a weight bracket in the bed.. if the don't want front weights.. Do a search on this forum for front weight brackets.. ladder bars.. pulling hitches not sure I have seen many threads for blocks..
Bryan
Edit:.. You should be able to build most of those things.. The search should give you some good ideas...
Old Nov 19, 2007 | 04:01 PM
JIT's Avatar
JIT
1) 26in Max Hitch Height (where the hook will lay)
2) Go to a truck stop and get your truck weighed... you want to be as close to 8,000lbs as possible without going over.
3) Traction Bars & Blocks
Then go pull and talk to the locals find out what power adders you can use and go from there!
mullercarl
Competition / Pulls / OffRoad
45
Mar 19, 2007 10:10 AM
Swoop411
Feb 28, 2005 01:21 AM
505diesel
Feb 15, 2005 08:40 AM
MossMan
Feb 14, 2004 12:03 AM
olchevrepl
20
Oct 29, 2002 08:14 PM
