pulling help
Old Jul 17, 2008 | 09:40 PM
curts99's Avatar
pulling help
going to be pulling sat the 26th the pull im going to has one class 8000lbs run what you brung. so leave it in 4hi and 1st or 4lo and let it shift mind you this is my daily driver so i dont want to be too hard on her (but yet im pulling it go figure). also should i make the rear suspention ridgid a little play or leave it. also with me in my truck full tank of fuel she weights in at 6980 so should i hang the whole 1000 out front or none or just a little weight. any advice would be great. kinda goin into this blind.
Old Jul 17, 2008 | 10:08 PM
Rpainter's Avatar
4 lo, start out in 2nd and leave it there maybe 3rd depending on track. if you have time make extensions for the bumpstop. and letsome air out of the front tires. and hang weight if you feel brave.
Old Jul 18, 2008 | 08:56 AM
curts99's Avatar
how much air should i let out and im feeling brave
Old Jul 18, 2008 | 09:57 AM
Bad-Duvall's Avatar
i drop my air psi down to about 20psi and hang about 1000lbs on the front,
Old Aug 25, 2008 | 08:02 PM
Extreme Flight's Avatar
how close should you put the bumpstops to the axle
Old Aug 25, 2008 | 08:55 PM
dieselrob's Avatar
It depends on the rules. Around here they say you need 2 inches or travel.
smalltownTPull
Jul 6, 2009 09:04 AM
CTD03
Competition / Pulls / OffRoad
21
Jul 23, 2007 11:41 PM
mullercarl
45
Mar 19, 2007 10:10 AM
boiler-rat
Sep 20, 2006 06:46 PM
Dan Marino
16
May 21, 2006 09:07 PM
