one bad duramax
one bad duramax
i havent seen anything posted on here about IBDMAX`IN and his dyno run,,,,so i thought id post it.....835/1723 in an 02 with nos/pane,thats from i hear a best number 2 only run to date of 513/9**.....thats a jetpilot squirt fer sure wouldnt you say?....so whos gonna be the one with an indestructible cummins powerplant that hoses one to over 800?c`mon now,jetpilot wasnt skeered!........................bama
Originally Posted by iker42
NO THATS ... !!!!HE used nos and pane..IMO sissys use nos to boost their numbers
Sissy's use nitrous? Go ahead and hook it up to your ride and see how much you can make.... There is a lot more to nitrous than just hooking it up and hitting the juice. Come on over to my place and I will show you my "wall of headgaskets" blown while tuning a nitrous truck for max HP. I never worry about making HP on #2, but with the spray things get tricky and go Boom.
Doug
There is a Duramax that put down 660+ 1400+ on number 2 only. And yesterday Mtomac ran 12.02 at 112 mph on #2. (He backed that up with a 12.05 @ 112 mph!)As far as I know both are current records for the Duramax.
I can't remember his full name or what company he works for, but there is a guy named Kyle that is runing a dmax in the sled pulls now that is making tons of power on #2 and water/meth only! He is pulling up against all those pro class cummins trucks and took home first at the Charity pull! I don't know if they have dynoed it yet but I will guess he is in the 800hp range on #2 and water/meth!
You fellas ought to leave Jetpilot alone, he has made more HP than just about any 2 of us combined.... With that Said, Darren Morrison's Prostreet truck made 795 HP on wet rollers in the rain Thursday and ran a 10.402 at 129 MPH Yesterday... On Fuel......
We do have a little 4x4 down here that made 808 last friday. He did cheat a little bit, though. Spraying a little water with 25 % meth. Then saturday ran the quarter mile , and got a 10.30 at 128. I know those ain't the best numbers around but still pretty good , I thought. And the truck weighs in at 5,580 lbs.
..Preston..
..Preston..
brandon.
NO THATS .... !!!!HE used nos and pane..IMO sissys use nos to boost their numbers
Mike
Mike
for those of you that have seen darrens truck run,,and just saying that it would hold together,what do you think he could get on the spray?im betting that if it could hold together,he would be in the 1100-1200 hp range easily.....and personally,,i dont think dougs a sissy ..........bama
Originally Posted by joefarmer
Kyle's not running water/meth, just a large charger.
brandon.
brandon.
ted
Originally Posted by p-pumped
he is running water no meth though. there is a little more under there than just a big charger but no drugs.
ted
ted
i have to laugh how drugs are so bad when they blow by the cummins, but all the aftermarket bolt ons you cummins boys can add is ok, biger chargers, sticks, all the head work, bottom end work and the list goes on
and then to find out the main reason is that drugs just do not work that great with the cummins
also keep in mind our cost compared to your cost for the extra power power
now how many cummins in the 850 range on a stock motor with drugs
i rest my case
i rest my case
