Oct 13 pull
Old Sep 19, 2007 | 08:21 PM
turbopwr's Avatar
Oct 13 pull
There will be a truck and tractor pull in Tollesboro Ky on oct 13. Having 2.5, 2.8 an open classes.
Also, John Issacs from Floor It Diesel will be there all day with his dyno. So come out, put your truck on the dyno and hang out for the pull.
Lowrey Patriot Sled
Old Sep 23, 2007 | 09:39 PM
gotsmoke_77's Avatar
Do you know what all tractor classes and truck classes they're pulling??
Old Sep 25, 2007 | 06:43 AM
Hired Gun's Avatar
I am not familiar with this dyno? I trust only David Dunbar. Can you fill us in on more details? Will dually trucks fit? Cost? Sign ups? Lots of people wondering.
Old Sep 25, 2007 | 09:15 PM
turbopwr's Avatar
I've searched forums and talked with several different people about this dyno, everyone says that it is the closest to dunbars with more ability to load trucks to lit bigger turbos. All the reports he has got back says that his and dunbars are within 12 hp at the max. Sure some trucks will do different things, depending on its reaction and what load it likes. $75 for 3 runs. Come out and enjoy. Will check soon on duallys.
Farm stock 2-6000#, 7500#, 9000#, 10500#, 12000#
Factory farm 9500#
Pro farm 8500#
8000# diesel truck, 2.5 and 2.8
First truck class (2.5) should pull around 8pm, second class (2.8) around 10pm.
Old Oct 7, 2007 | 09:19 PM
turbopwr's Avatar
TOLLESBORO LIONS CLUB
FALL SMOKE-OUT
Sat. Oct. 13 @ 6pm
Gates open @ 9am for DYNO
Classes: (in pulling order)
1. 6000lb. 2-3-4 cylinder
2. 6000 lb. 2-3-4 cylinder turbo, 6 cylinder no turbo
3. 7500 lb. Farm Stock
4. 8000 lb. Hot Street Diesel Truck: 2.8 inlet single charger, turbo may be bushinged, suspension can be blocked, DOT street tires, weights hanging no further than 60 inches from center of front axle, NO propane/NOS injection, 26 inch hitch height, no trick hitches, must have drive shaft loops, ladder bar loops, u-joint shields, kill switch, 2 cross bolts in exhaust, (stock turbo trucks can pull w/out safety equipment).
5. 8500 lb. Modified Field Stock
6. 9000 lb. Farm Stock
7. 8000 lb. Open Diesel Truck: Must have all safety equipment, hot street trucks will be allowed to pull in class.
8. 8000 lb. Street Diesel Truck: 2.5 in. turbo, turbo may not be bushinged, suspension can be blocked, no water/alcohol/NOS/propane, weights hanging no further than 60 inches from center of front axle, DOT street tires, 26 inch hitch height, no trick hitches, if equipped with ladder bars-must have a retaining strap
9. 9500 lb. Factory Farm
10. 10,500 lb. Farm Stock
See how much power your truck has with the:
Truck Dyno starting @ 9am until 6pm
Old Ironsides: The Patriot Sled
For info call Matthew @ 606-782-2373
Old Oct 7, 2007 | 10:36 PM
XLR8R's Avatar
Isn't 8000# a bit light? 3rd Gens with 4WD and a real bed (most come with 4 doors) are going to miss that, especially with replacement bumpers, or a toolbox, or a full tank of fuel.
"Work Stock" by definition often translates into near-GVWR on the scales...
Old Oct 12, 2007 | 08:12 PM
turbopwr's Avatar
So far we have had 4 open mod trucks that said they where coming, and a lot of 2.8 trucks.
Dyno will be there all day, come and see what hp and tq you got.
Hope to see ya there.
12 mile east of maysville on aa highway on left.
shortround
Oct 14, 2006 10:32 AM
Shovelhead
Oct 30, 2004 11:28 AM
shortround
Oct 23, 2004 07:44 AM
hotdram
Oct 9, 2004 09:52 AM
Mostwanted
Oct 11, 2003 01:34 PM
