New Record 11.3 @ 117
Old May 7, 2007 | 07:00 PM
johnsjas's Avatar
On HTS's website there is supposed to be a picture of that truck. It also says that there is a CR running 11.4 on fuel only.
Old May 7, 2007 | 07:28 PM
Robert P's Avatar
Originally Posted by Dockboy
Robert,
Just exactly how did you figure it is less than 50 hp worth of nitrous?
First of all.....just what is 50 hp worth of nitrous?? There is no such thing!! That is not how it works
Second, from his own mouth....... Well.........I run 2 .060 jets and gain 175 hp
You guys really do need to understand what you are talking about before making statements that don't make sense
at 700 psi max, he was getting almost no nitrous. also greg, he did not use 2nd stage but for a second in fear of melting the motor.
Old May 7, 2007 | 07:32 PM
Dockboy's Avatar
What is this......The Larry, Moe, and Curly Show on how to use nitrous?
Old May 7, 2007 | 08:21 PM
Luken's Avatar
The 11.41 fuel only run was member greyrig who has the baddest 3rd gen IMO. James only got one run at the track because he didnt have a rollcage. Who knows what it would get with a little tuning and a better launch...
Everything aside Im just happy to see the common rails making a move.
Once again, congrats.
Old May 7, 2007 | 09:48 PM
getblown5.9's Avatar
wade had an ounce of respect there for a day or two and now its all being blown away by these new "findings" and claims of no nitrous in the bottle, and only running one stage, and head winds he was up against.
looks like a ton of excuses again, guess we will see in bowling green. ill be sure to make sure i get the exact wind readings so if he runs an 11.3 again with a head wind we will know for sure its a 10 second truck.
Old May 7, 2007 | 11:27 PM
XLR8R's Avatar
Since when does adding more NO2 cause a diesel to Melt?
Old May 8, 2007 | 03:41 AM
Robert P's Avatar
more NOS makes more heat.
Old May 8, 2007 | 03:43 AM
Robert P's Avatar
TJ, NOS was in the bottle when he ran 11.3 no doubt, but on sunday it was a different story. i just wanted to tell the whole story not some half true story.
Old May 8, 2007 | 05:47 AM
Pack Mule's Avatar
since when does nitrous make more heat???? drive pressure cylinder pressure i could definatly see, but heat, no.
Old May 8, 2007 | 07:33 AM
mcoleman's Avatar
More heat with nitrous? That's funny right there.
Old May 8, 2007 | 08:01 AM
XLR8R's Avatar
Spark Ignition: more NO2 (leaner combustion charge) = hotter
Compression Ignition: more fuel (richer combustion charge) = hotter
You can't melt the piston crowns on a diesel with too much air - or NO2
Old May 8, 2007 | 09:43 AM
Hired Gun's Avatar
Are you guys talking about the Las Vegas event? If so the Duramax was McRats truck with Kat driving. on #2 only. I think they call the truck Casper.
Old May 8, 2007 | 02:21 PM
Robert P's Avatar
now wade has his reasons but this is what i understand:
NOS makes for more cylinder psi and more psi makes heat, couple that with alot of fuel and a 66mm charger/ stock cylinder head and you have lots of heat. he said egt's were 1600 by the 1/8 mile mark.
Old May 8, 2007 | 02:49 PM
mcoleman's Avatar
He must have a freak truck then. Nitrous has dropped or leveled EGTs on every truck I've been in. And it usually drops it.
Old May 8, 2007 | 03:06 PM
oil_burner's Avatar
It's my understanding you can spray all the nos you want ,but without the fuel to support it , it will make the motor lay down like a dog. right?
