Ladder Bars
Old Nov 22, 2006 | 09:14 PM
  #121
XLR8R's Avatar
Depends on what design of ladder bars you're getting.
How do they mount to the axle?
Old Nov 22, 2006 | 09:45 PM
  #122
streetsmoker's Avatar
Under axle even with bottom of shock bracket. Between shock and leaf springs and as close to parallel to the frame as possible. They are very similiar to the ones you made. Just not as heavy or overkill.
Old Nov 23, 2006 | 12:21 AM
  #123
XLR8R's Avatar
Under acceleration, bars of that design will be subjected to compressive force, so preload them by lengthening with the heims so there's no slack.
Old Nov 23, 2006 | 09:07 PM
  #124
Thanks alot. Now I'm ahead of the learning curve!!!
Old Nov 25, 2006 | 07:03 PM
  #125
Robert373's Avatar
XLR8R-Can you post some pictures. I am really curious to see your bars installed.
Old Nov 25, 2006 | 07:46 PM
  #126
XLR8R's Avatar
TexasCTD should have some installed photos next week; after a number of hard launches to seat the brackets, I adjusted the play out of the bars - one half turn each longer, which changed the pinion angle a degree or so and jacked up the rear over one-quarter inch. Now, they're quiet again.
Old Nov 27, 2006 | 12:03 AM
  #127
Robert373's Avatar
Awesome. What pinion angle did you end up with after adjusting the bars?
Old Nov 27, 2006 | 12:12 AM
  #128
XLR8R's Avatar
I didn't measure it again, but I'm sure it's still ~ 2*, or I'd hear the U-joints shuddering on takeoff.
We just pulled the aluminum GN back from the shop an hour ago, and the ladder bars sure cut down on the "rodeo" ride with the trailer.
Old Nov 27, 2006 | 12:20 AM
  #129
Robert373's Avatar
After hearing comments like that, I might have to just look more seriously into doing this....I sure like the Glacier Diesel design, but there is something to be said for the simple design you used.
Old Nov 27, 2006 | 12:28 AM
  #130
XLR8R's Avatar
It's worth it just for the burnouts!
Old Jan 21, 2007 | 11:49 AM
  #131
BCB's Avatar
BCB
any pictures yet?
Old Jan 21, 2007 | 10:05 PM
  #132
XLR8R's Avatar
Here's a side shot that also shows the heavy-duty step bars I made:
Old Jan 21, 2007 | 10:06 PM
  #133
XLR8R's Avatar
... and driver's side rear bolt-on mount:
Old Jan 22, 2007 | 07:37 PM
  #134
BCB's Avatar
BCB
looks good how long are they and what size pipe did you use?
Old Jan 22, 2007 | 10:14 PM
  #135
XLR8R's Avatar
Originally Posted by BCB
wow what size tubing is that and how long are they?
It's triple-butted pipe, 2.375" OD with a wall ranging from .150" up to .335" with 1.125" heim joints on the ends. They are 94" stem to stern and weigh 65# per side complete.
I answered your question back in November... hopefully you catch my answer this time!
