Ladder Bars
As mentioned, the longer the bar the less the bind in the spring as the spring compresses and the bottom of the axle is forced to travel along an arc. The downside is that the longer the bar the heavier they must be to resist buckling. A bar that's twice as long will require a moment of inertia 4 times greater to withstand the same critical load.
SmokenRam-
you have a pic of how the bars attach to the frame? how about a shot from the back?
I originally planned a set of bars that would rotationally lock to the axle tubes, which would have placed the bars under substantial buckling force (large upward bending moment at center of bars' length); instead, I chose to make bars that mount to the lower shock brackets, which (upon traction-induced axle torque) subjects the bars to ONLY compressive forces - a load that the bars can withstand better by an order of magnitude....
and of course the long bars have better leverage on the mass of the vehicle.
Guest
Posts: n/a
Ladder Bars
Hell I thought about buying me some of those metal bars but there too daw gone expensive. So I just went out in the woods cut me a couple saplings down (small trees) bout 14 inches around. Used a little binder twine and some wire to fasten them bad boys down. Hell I yank them ford guys around all day long. Makes my truck look like a skidder. A big truck with logs underneath getting all that power to the ground...priceless. I'll try and get some pics
Anxiously awaiting pictures
