July 21st pull whos coming?
Wauchula, Florida sled pull is coming up and it looks like its going to have a big turn out. Its hosted by Edited by Admin most question can be answered there. If your are in the florida area you will want to try and make this one it should be one of the biggest diesel gatheings in florida yet. The track and bleachers are covered so rain shouldnt be a problem. Whos coming from the Diesel Truck Resource Forums ?
That's a pretty crappy thing to do. PM sent to you.
The big building in the center of this link is where it's held.
http://maps.google.com/maps?hl=en&q=...&t=h&z=17&om=1
Classes are: Stock diesel- 8200lbs programers, exhaust ok - no hanging weights.
Superstreet diesel- 8000lbs aftermarket injectors, turbos #2 only
Modified diesel- 8500lbs as trick as you can go
Open- 8500lbs gas and diesel
Superstreet diesel heavy- (in the works) same as superstreet but no weight limit for those heavy trucks that never have a chance of making weight.
***26" hitch height reese style only unless in modified or open***
I'm leaving out some of the details but this should help.
Superstreet heavy I mentioned above will only happen if there are a minimum of five heavies there by 3:30pm. Normally a lifted duelly 4 door w/37" tires or bigger and maybe a winch can weigh 8800-9000 lbs.
Anybody fit this and planning on coming? I know of three so far for sure need two more.
