How to launch with a manual
Old Dec 7, 2007 | 10:37 AM
XLR8R's Avatar
Originally Posted by RAT_03
I put it in 4x4, to just under redline. Hold the brake and start easin out on the clutch till I dump it, shift through 1st 2nd 3rd and 4th without letting off the throttle.
You launch in 1st?
Old Dec 8, 2007 | 01:29 AM
RAT_03's Avatar
DTR's "Secret Agent"
haha, i messed up, nope 2nd gear.
Old Dec 8, 2007 | 01:32 AM
Tate's Avatar
In a 6 speed? 3rd isn't much or a stretch in my truck, and its higher than 3rd in the 6 speed.
Old Dec 8, 2007 | 09:50 AM
wildmanben's Avatar
Originally Posted by 97' CTD
You still got the truck Ben I know you had it for sale?????????
Brandon
Yeah still got it. The wife didnt want me to sell it! Imagine that. Now I got some more toys in order for it. Pulling season is only a few months away!
Old Dec 9, 2007 | 09:15 PM
Canamboy's Avatar
When i was goin to pull mine. I talked to the guy that owned it before me and he pulled it once. He said to put it in 4th in 4 low rev it up to 2100 rpms and then start lettin the clutch out slowly. He knew what he was doin and it was a floating finish and he pulled the sled 350ft!!!
Old Dec 11, 2007 | 11:40 PM
GLHS's Avatar
We are talking drag racing, right?
I rev it up to 3000 rpm, and on the 3rd yellow, let it out quickly but as smooth as possible as I stomp my right foot down.
Best 60 foots are 1.94. So far, can't get them any better.
I side stepped it once by accident, and it felt and looked (by others) that all 4 tires left the ground.
Suprised nothing broke.
Old Dec 13, 2007 | 12:36 AM
merr6267's Avatar
Press clutch and brake.
Position shifter in 3rd gear.
Keep heel on brake and use toe to press skinny pedal all the way in.
Wait for it.
Wait for it.
Slowly let out the clutch.
Wait for it.
Watch boost gage.
Wait for it.
See it flash past 30 psi.
Let off the clutch completely.
4 Wheels in pain and a lot of heat in the clutch.
Oh, and this . . .
Take care,
Phill
Old Dec 13, 2007 | 05:33 AM
XLR8R's Avatar
Looks like that one sprained your wallet!
Old Dec 13, 2007 | 09:53 PM
Ph4tty's Avatar
I've tried literally dozens of third and fourth gear launches, but have come to the conclusion that if I start in second and short shift into third it is just as fast as launching in third. Less wheelspin, less wear on the clutch, and faster off the line
Old Dec 14, 2007 | 11:34 AM
XLR8R's Avatar
^^^ I agree, that's been our experience as well.
However, since the '05 still has gear left at the big end of the track, we're going to reconfigure the launch for next season. Using relatively small diameter tires with a relatively wide footprint (that can still handle the trucks race weight) we'll launch in 3rd with the new clutch no problem. By eliminating one gear change - the hardest one - and improving the 60' I expect a better ET and a modest increase in MPH... of course, the reduced rolling resistance, frontal area and rotating mass of the new shoes will help, too!
Old Dec 15, 2007 | 03:06 PM
SlowSixSpeed's Avatar
Originally Posted by getblown5.9
pulled a 14.2@100mph by putting my 6speed in 3rd, then holding the rpms at 3200, and slowly but steadily just let the clutch out. its slips a little, gets the boost up and was still able to pull at 2.2 60' then shift easy the rest of the way down the tracks.
here is a video of some of my slower runs that day, didnt get the 14.2 on video
http://www.youtube.com/watch?v=JQwSP6OdK54
Doing that actually hurt your times.
You would of been alot better off just reving it to 2500 in 2nd gear 4x4 and dump it.
You have a better ET and MPH then me but I have a better 60ft. 1.97 and 2.02.
Sounds and looks like it was slipping.
Old Dec 29, 2007 | 05:08 PM
05_lly's Avatar
3rd gear, Ebrake on, 3500 rpms, slip er a just a bit and let er fly. Gonne try a line lock an some weigh reduction for 08, Lookin fo a 11.xx pass!
best 60' of 1.71
best ET 12.55 @ 108MPH
Heres a vid of the launch on the 12.55 run.
RT .031
60' 1.801
1/8 7.985 @ 87.04
1/4 12.559 @ 108.59
http://www.youtube.com/watch?v=UXBk0weT8Hc
Old Dec 29, 2007 | 05:20 PM
ramtd02's Avatar
I just installed my line lock and SPEC super twinn....and we will see where that gets me next year. This year with a slipping clutch till the 330' ended up like this.
60' = 2.466
1/8 = 8.802@86.96
1/4 = 13.116@109.45
ran a 12.8 on my g-tech which is pretty accurate, but couldn't back it up at the track. It was when the clutch was still new.
Old Dec 29, 2007 | 06:30 PM
05_lly's Avatar
What type of line lock did you install? Have you tried it out yet?
Old Dec 29, 2007 | 07:58 PM
ramtd02's Avatar
I got it from summit racing....and I tried a few so far....so far i can build about 15 psi of boost before the truck breaks free of the brakes. Which is pretty much perfect.
