good high power clutch, south bend.
Old Nov 7, 2007 | 06:36 PM
  #31
stock600's Avatar
thanks its been ordered. I was just looking at shipping time from there to texas.
Old Nov 7, 2007 | 07:21 PM
  #32
afoulk's Avatar
are the 3850's easy to live with in a daily driver? If the pedal effort is maybe slightly less than a semi, I can deal with that. Are they "grabby" when pulling out?
Old Nov 7, 2007 | 08:00 PM
  #33
P.J's Avatar
P.J
What did you get, the single?
Old Nov 7, 2007 | 08:14 PM
  #34
P.J's Avatar
P.J
I don't have that plate load, but the only time mine gets jerky is while loaded heavy and trying to back up. You get used to it though. I had one other issue when I was trying to pull out and turn while facing up hill in a camp ground, I actually had to let it roll back down to a flat spot to get her to hook up without shaking violently.
I only had about 750 miles on it at that point though, and haven't been in that situation again since.
Old Nov 7, 2007 | 09:16 PM
  #35
stock600's Avatar
P.J. yea i went with the south bend single disk con fe. Thier high but i would'nt complain prob. after hearing prices on dd. At my power level whatever that is, and the driving i do the fe is overkill. But thats the way i want it, i want to be able to lean on it and not worry. If there was a chance of hooking to a sled like many of you do it be diff. but theres not much of that dont here in tx that i now of. The occ. trip down the 1/8 mile and lots of punishing those fords and chevys on the street. he he
Old Nov 8, 2007 | 04:32 AM
  #36
P.J's Avatar
P.J
Cool, I'm sure you'll be fine with that. The DD prices are scary, thats for sure.
Old Nov 8, 2007 | 10:01 AM
  #37
Muddin_dude06's Avatar
ValAir's dual disk should be out pretty soon, should be 1/2 the price of a South Bend. I am getting one ASAP...
Old Nov 19, 2007 | 07:51 PM
  #38
merr6267's Avatar
I run a 3850 with the 24 feramic buttons in my truck and while I don't like the fact that it's a manual trans in the first place, the clutch is amazing.
I have fried it with 4wd launches in 3rd gear probably 50 times and who know how many the PO did. It still has plenty of meat left in it, just the iron parts are a little purple now . . .
I broke the cluster gear, which is the only reason that I removed it.
It's a little grabby now, but that's just because it's a little bit fried. The pedal effort honestly does not seem much different from my stock 2.8L S10.
Old Nov 19, 2007 | 11:23 PM
  #39
GLHS's Avatar
Hope you don't plan on too many trips down the track. I took care of an FE already then Peter sent me something different.
Who makes a quick shifting dual disk? Is Haisleys Street Drag the only one?
Old Nov 20, 2007 | 12:17 PM
  #40
stock600's Avatar
GLHS, seeing that the clutch is rated 100hp more than the power in your sig id say you got a bad one or you have bad driving habits. I got mine put in sat. it will hold the power but its noisey as heck idleing in neutral, push in the clutch OR come off idle and its normal. Little grabby but it does hold the power i think im in the 480-500 range right now.
Old Nov 20, 2007 | 09:11 PM
  #41
lmills's Avatar
FE is noisy in neutral?
Old Nov 20, 2007 | 09:32 PM
  #42
dodgezilla04's Avatar
that's what i am wondering lloyd. isnt the reason a dd is loud is because of the center disc chattering?
the only reason a single should chatter is the TO or pilot is not installed correctly or faulty
Old Nov 20, 2007 | 09:56 PM
  #43
lmills's Avatar
yes, I would be checking into it if it is making any noise. It should have the same manners as a stocker, just more agressive
jonjohnson
Apr 2, 2007 10:59 PM
biglar
Nov 20, 2006 10:08 PM
J.R. Adkins
19
Apr 15, 2003 10:38 PM
29
Jan 21, 2003 10:23 PM
