First time at the track!!
Old Aug 22, 2007 | 09:48 PM
13ALPHA's Avatar
I just got back from Bandimere here in Colorado, it was the "take it to the track night." It was awesome, never raced before, got there late and ran once, but I got a 17.921 with a R/T of .124. I know I can get better, but happy for the first go around.
It was mostly Ferds here, one other Cummins, but he ran a ~14 and wooped them
Does that time seem about right for my setup? I was wondering if the clutch could have slipped at all, I didn't feel anything obvious though.
One more, with a 5spd, how do you guys launch? I dropped it from like 2600 in 2nd.
Can't wait to go back!
Old Aug 22, 2007 | 10:15 PM
kawiram's Avatar
did you launch in 4HI? Looks like fun!
Old Aug 22, 2007 | 10:26 PM
13ALPHA's Avatar
No I tried 2H first, had a little wheel hop I guess no burnout, so guess I can try 4H next time and launch from a little higher RPM?
Old Aug 22, 2007 | 11:41 PM
13ALPHA's Avatar
Are there recomendations for launching the 5spd in my set up? Does the time seem about right? I thought it was slow
Old Aug 24, 2007 | 10:01 AM
01smoker's Avatar
That sounds pretty close to what it oughta be. You need to put a drag comp with some injectors in that bad boy. I always put mine in 4hi 2nd gear and I would rev it up to about 2500 and let it out slow at first until you hear that turbo start to spool and then let it out a little faster until it fully grabs. If you had a good clutch you could probably launch like that in 3rd. Your stock clutch won't take many boosted launches like that though.
Yeah you gotta run in 4wd to get these trucks to leave right.
Old Aug 24, 2007 | 01:09 PM
JoshH's Avatar
Those times don't sound too bad for a manual truck and being at high altitude. From what I've heard, Bandimere is a horrible track for getting fast times.
What was your 60' time and MPH?
Old Aug 24, 2007 | 02:07 PM
13ALPHA's Avatar
60' was 2.762 and 79.25 MPH
What's the difference between the edge comp and drag comp? I see the gains are the same 120hp and 350tq at level 5, adjustability is different?
Old Aug 24, 2007 | 02:18 PM
03qclb5spd's Avatar
I would be weary of a 4x4 launch in 3rd on a single disk. Good way to weld it all up.
Old Aug 24, 2007 | 02:29 PM
13ALPHA's Avatar
Next time I go I will have an edge comp on it, I will try the 4x4 launch, but in 2nd, I will be upgrading the clutch shortly. Thanks for the input, can't wait to beat those Ferds!
Old Aug 24, 2007 | 03:14 PM
03qclb5spd's Avatar
Good luck man!
Also, even if you upgrade to something like a South Bend you won't be immune to the chances of welding it up in 3rd. Believe me, I know.
Old Aug 24, 2007 | 03:29 PM
JoshH's Avatar
That MPH sounds real good. If you can get your 60' down to the sub 2 second range you should be running 16s easily.
Old Aug 24, 2007 | 03:47 PM
1stGen545's Avatar
A set of track bars for the rear would help with the hop. Good looking truck
Old Aug 26, 2007 | 10:12 PM
01smoker's Avatar
The drag comp fuels to 3200 rpm and the regular comp fuels to 2700 rpm. The drag comp feels much stronger even though it isn't supposed to gain any power. My old 01 ran much better with the drag upgrade.
Luken
Competition / Pulls / OffRoad
Jun 17, 2006 10:33 PM
runamuk
Mar 23, 2006 10:44 PM
getblown5.9
Apr 11, 2005 09:11 PM
My 03 HO
Jun 21, 2003 10:09 PM
