Eldon, IA pulls Oct 6th
Old Sep 11, 2007 | 03:26 AM
dieselfite's Avatar
Wapello County Fair Grounds we we be having a truck pull which will incldue gas trucks, diesel trucks and open to the tractors that show up. 5pm start time with weigh startin at 3:30. We are working to see if we can get a dyno to show up also. Stay tuned for more info and open diesel payout.
Old Sep 16, 2007 | 08:30 AM
dieselfite's Avatar
We are having a show-n-shine also sateting at 2 pm. Anyone on here coming?
Old Sep 16, 2007 | 09:38 PM
Power Ram 250 C's Avatar
where is it going to be located at?
Old Sep 17, 2007 | 11:09 AM
CNeubauer's Avatar
The fairgrounds are on the east edge of town on highway 16 on the south side of the road, you can't hardly miss them from the highway.
Old Sep 17, 2007 | 03:02 PM
dieselfite's Avatar
If you are coming from the north you will go all the way through to the other end of town on 16 and it will be on your right. Hope to see you guys there.
Old Sep 19, 2007 | 11:35 AM
dieselfite's Avatar
Just wanted to clear this up this is a truck pull and the only tractors that we will pull will be the Twin States tractors. So if you fit in that classes they will pull last.
No farm stock or antique tractors will be pulling.
Old Sep 26, 2007 | 12:44 AM
dieselfite's Avatar
6500lb – Pure Street
6500lb – Stock Street – Small Block
6500lb – Stock Street – Big Block
6500lb – Pro Street – Small Block
6500lb – Pro Street – Big Block
6500lb – Open Street
8000lb - 2WD Diesel
8000lb – Stock (NO Smoke)
8000lb - Single wheel Diesel
8000lb- Dually wheel Diesel
8000lb – Pro Diesel
6500lb – Modified
All of these classes will payback 100%
Old Sep 30, 2007 | 07:51 PM
bigdave's Avatar
Which class can I run my truck in and will it be at all competetive or emberassing?
Old Sep 30, 2007 | 08:20 PM
CNeubauer's Avatar
There will be at least a couple 500+ hp trucks there based on other pulls in the area this summer but you never know who might or might not be there. It sounds like there couple be a few Duramax's coming down from the Fantasy group so it could be a real good show.
Old Oct 7, 2007 | 12:59 PM
CNeubauer's Avatar
I'd like to thank Kendall, his helpers and the sponsers for putting on this pull last night. I thought the turnout was pretty good for a first time event and the tittle of "the toughest 300'" was very fitting. The track claimed two transmissions, a rear axle pinion shaft and a Ford 6.0 that I remember but I think alot of people were sirprised there wasn't more carnage. Dodge took both the dual wheel class and the pro-street class and led the diesels in the open class.
outlawdra
Competition / Pulls / OffRoad
Oct 7, 2012 10:17 PM
satburn
Oct 9, 2006 03:55 PM
shortround
Oct 23, 2004 07:44 AM
hotdram
Oct 9, 2004 09:52 AM
Mostwanted
Oct 11, 2003 01:34 PM
