DynoJet results...
Old Dec 17, 2006 | 11:13 PM
rockjeep73's Avatar
DynoJet results...
Well I ran my truck on a dynojet for the 1st time on saturday and I was pretty impressed with the results. The only other time I have dynoed was on a mustang and I put down 352/660 with water/meth.
On the sheet below, run #002 was with water/meth, and its just about the same setup that I ran on the mustang. Run #003 was with my new nitrous setup and no water/meth. Run #004 was with water/meth and a very small amount of nitrous, as you can tell. I am still running the stock HX35 and stock injectors.
Old Dec 17, 2006 | 11:49 PM
one54ton's Avatar
very impressive for you little 35...at least its staying cool.
Old Dec 18, 2006 | 12:57 PM
RowJ's Avatar
You got 66HP/206 ft-lb more on a Dyno Jet than on a Mustang??
RJ
Old Dec 18, 2006 | 03:26 PM
rockjeep73's Avatar
The changes made to my truck since I dynoed on the Mustang are:
1. Ported head with .020" gasket
2. F1 valve springs
3. Ported exhaust housing and enlarged wastegate (set to 32psi)
4. I dynoed in OD instead of 3rd
Fueling is the same, water/meth is setup the same with 50/50 mix.
Old Dec 18, 2006 | 03:54 PM
inline6power's Avatar
rockjeep, may i ask you have done for fueling?
Old Dec 18, 2006 | 09:03 PM
rockjeep73's Avatar
TST powermax competition, Edge EZ, and a II HRVP-44 through the stock injectors.
Old Dec 18, 2006 | 10:53 PM
very nice numbers. kinda gives me an estimate on what i have plus 170hp sticks.
Old Dec 18, 2006 | 11:01 PM
you could easily have a 500hp plus truck with some injectors and a turbo very nice setup. seems to work well with your truck.
Old Dec 18, 2006 | 11:12 PM
bigwhite59's Avatar
A dynojet inherently reads higher than a Mustang Dyno. I own a small performance shop specializing in late model GM muscle cars, for the ECM tuning, a dynojet is basically useless as it does not load the motor for a true A/F ratio reading. Dynojets give pretty numbers, but mustang dyno's are a more realistic idea of what hits the ground, plus much better for tuning purposes.
Old Dec 19, 2006 | 07:58 PM
John_P's Avatar
rockjeep:
Nice numbers!
John_P
GLHS's Avatar
I agree. When I dyno on a Mustang the pyro sky rockets and power goes down. It loads my truck harder than driving down the track. It makes a lot of pre intercooler heat without enough air to cool the intercooler.
Notice any difference driving since porting the head? Do it yourself?
Kurt
Old Dec 19, 2006 | 08:47 PM
rockjeep73's Avatar
I noticed the same thing when on the Mustang, pegged pyro and a lot more load on the truck than drag racing.
I did the head myself and I dont have accurate results to compare before and after because when I had the truck apart I ported the exhaust housing on the turbo and enlarged the wastegate in order to keep the boost down to 32 where I want it instead of 35 or more. I also put it back together with a .020" thicker headgasket and the new valve springs, so with all the changes at once I cant say the effects of just porting the head. The truck did run about 3-4 tenths quicker after all of this was done.
Old Dec 20, 2006 | 12:18 AM
XLR8R's Avatar
From the dyno sheet, it seems as though you don't have enough fuel dialed in to support the use of nitrous... acts as if combustion is being quenched when you add the cooling effect of nitrous on top of the water/meth system.
Old Dec 20, 2006 | 12:26 AM
rockjeep73's Avatar
Ya, im aware that I am lacking fuel, but im trying to get everything I can out of the setup, before I move on.
Old Dec 20, 2006 | 12:28 AM
rockjeep73's Avatar
Originally Posted by XLR8R
...acts as if combustion in being quenched when you add the cooling effect of nitrous on top of the water/meth system.
May I ask where in the graph you see this?
