drag racing in 4hi with front locker
any of you drag racers have a locker in the front? how does it behave in 4x4? I want to get a locker for the front for offroading and am wondering how it will affect 4hi launches and stuff
im not buying it for drag racing, just offroading. im just wondering if I will have any problems racing with one using 4hi. maybe I can just lock 1 hub instead of both. that might be ok. and turnin at the end of the track will be ok, it will be a cheaper rachet locker, not a full detroit.
Trying to launch with only one hub locked in will result in an instant u turn, it will not be pretty.
I had a locker in the front of my old 93, keeping the truck straight was impossible over 35-40 mph on hard surfaces.
An ARB would be your best bet, so you could unlock while racing.
Rick
Rick
I run an ARB in the front, and only use it locked when racing. I lock it before I stage, and unlock it after the finish line. You have to remember to unlock it before turning off the track, or you will not be able to make the turn. Kinda like forgetting to take it out of 4x4 only worse. Having the front locked helps with the consistency, not only at the launch, but also helps with tire slip during the 1-2 and 2-3 shift. One word of caution... Put the switches where you can get to them in a hurry. I have never had a problem, but if you get in a situation where you need to turn, you will want to unlock the front. I have about 400 passes with the front end locked.
Paul
Paul
Seriously I can get it off the track with the front locked. After doing it a couple of times though, it will make you remember to unlock it. As far as going down the track I have plenty of input to correct for torque steer if it spins off the line, and things like that.Paul
