Clevis Pin & Hitch
Old Jul 29, 2005 | 04:14 PM
satburn's Avatar
Clevis Pin & Hitch
Do you guys use a large nut on the underside of your pin to keep it from binding?
Old Jul 30, 2005 | 05:58 PM
PourinDiesel's Avatar
That is a good idea or some washers.
Old Jul 31, 2005 | 09:48 AM
Asher's Avatar
Is that an acceptable tow point for the sleds??? I sure thought that I would need something with more beef... If so, great I probably have one of those in the garage or in my jeep....
Thanks
Dave
Old Jul 31, 2005 | 12:35 PM
TxDiesel007's Avatar
Check out my latest pics..
I think for certain that clevis will hold.. It has the screw top on it, and it has been tightened very well with a pipe wrench. It has survived one tree stump yank already.. no issues... Acceptable for a sled? yes it is, as long as it isnt over the 26" max ride height..
Tx
Old Jul 31, 2005 | 04:11 PM
Kroner's Avatar
Thats how mine looked on thursday night and it held.
Old Jul 31, 2005 | 04:55 PM
Kman9090's Avatar
mine too!
Old Jul 31, 2005 | 10:38 PM
ihpower's Avatar
i have never had any problems with just a hitch pin in the clevis
Old Jul 31, 2005 | 11:02 PM
Crimedog's Avatar
One thing I'll add is you want to add some gussets to the hitch. I put 2 hooks on a setup identical to that, but it bent that thick piece of steel down about an inch. I welded a gusset into it on both sides and also sleeved the tube, now it's plenty sturdy I'll try to put a pic in my gallery soon...
Old Aug 1, 2005 | 03:41 AM
Ramtough's Avatar
The screw type are better. If and yes i know its a big if, IF the Gold pin ever bent it would slip out. The little hitch pin is not as secure as the screw in type. Least thats for offroad recovery. I should think safety is safety though.
Old Aug 2, 2005 | 08:30 PM
satburn's Avatar
Well, it held on my first pull, but other things didn't....
http://www.satburn.com/pictars/1stTruckPull.wmv
Dear Mitchell.....
Old Aug 2, 2005 | 11:10 PM
That is some scary stuff..
watchin that object go up like it did... OMG.... not to mention heart, gut and pocketbook wrenchin..
Tx
Old Aug 2, 2005 | 11:16 PM
joefarmer's Avatar
That always hurts to watch footage like that. Oh well, that's why it's called racin'! Get a good clutch in there and you should be golden! Is that your significant other sighing in the background noise?
brandon.
Old Aug 3, 2005 | 04:55 PM
satburn's Avatar
brandon.
Yeah, that was my wife and uncle discussing my clutch's destruction before I even hooked to the sled... a real pick me up. We knew going in, that it was going to be a weak point and most likely fail. The truck still drives just fine, other than losing a several thousand miles off the disc, it's no worse for the wear. But, I will be looking for a dual disc setup very, very soon...
Blacked Out
0
May 28, 2011 10:37 AM
West Coast
May 26, 2007 10:22 PM
Micaiahfied
Competition / Pulls / OffRoad
Sep 1, 2006 12:14 AM
bigragu
Oct 17, 2005 04:07 PM
Crimedog
Mar 11, 2004 01:54 PM
