Brush Pull in Neilsville, WI video, more carnage
Old Aug 14, 2006 | 10:10 AM
Bobcat698's Avatar
Thumbs down Brush Pull in Neilsville, WI video, more carnage
Went to a brush pull/fair pull Friday night... Results didn't turn out too well.
Looks like I'm finding most of the weak points, though
Click here to see Video
Dana 70 SRW unbroken axle shafts. (I run a Dana 80 DRW axle)
Random chunks...
Is my detroit unusable?
Do you think I could clean up the edges of that detroit and put a new bearing on it or is it totally shot?
At this rate I'll never make it to Scheids.. at least in the truck!
Old Aug 14, 2006 | 10:27 AM
crobtex's Avatar
Not really funny, but at least you're optimistic.
Old Aug 14, 2006 | 11:31 AM
Redline Ram's Avatar
Wow that launch was a little rough.
Old Aug 14, 2006 | 11:41 AM
Mcmopar's Avatar
Bobcat:
You are my new hero----unbelieveable!!!!! Besides, the man of steel has nothing on you now!
Old Aug 14, 2006 | 12:11 PM
gunracer1's Avatar
**** boy you could tear up a anvil with a feather. you need more springs in the rear or you have to start off a lot easier. and see if you can block the suspension.
Old Aug 14, 2006 | 12:14 PM
SmokinDodge12V's Avatar
A blocked rear is the only way you will get away with a launch like that.
Old Aug 14, 2006 | 01:24 PM
Bobcat698's Avatar
Yep, gotta get that fixed. I am running Timbrens right now and they must cause some of the hop.
Old Aug 14, 2006 | 01:57 PM
I hope you get it back together before Scheids, are you gona replace those axles with hardened axles.
Old Aug 14, 2006 | 06:46 PM
Bobcat698's Avatar
I took the ring gear out and cut the axles off and bolted them back in.. Got it up and running in front wheel drive.. Truck does some MEAN front wheel drive burnouts at 30PSI of boost J/K
Old Aug 14, 2006 | 06:50 PM
signature600's Avatar
Nice...Redneck engineering at it's finest. Do what you have to do to keep 'em moving!!!
So what are you going to replace them with?
Chris
Old Aug 14, 2006 | 08:39 PM
halerazor's Avatar
looks like it time to get ahold of haisley for some new axles. that bearing looks like it was never properly packed with grease. that was a rough launch.
Old Aug 14, 2006 | 09:45 PM
TravisG's Avatar
Somewhere deep down inside I don't doubt that you were in Plover doin front wheel burnouts.
Hope you get her back together. Come out of the hole sssssssssslllllllllllllllllloooooooooooooooowwwwww wwwwwwwwwwwwwwwww.
I gotta agree w/ halerazor about that bearing too. I would ask somebody about that maybe.
Old Aug 14, 2006 | 10:05 PM
Bobcat698's Avatar
Look everybody its Captain Obvious himself! Travis is the guy yelling "You Broke Garrett, you broke " in the video.
Yes, I think I'll come out of the hole SLOW when not hanging weights.
Old Aug 15, 2006 | 07:48 AM
gunracer1's Avatar
since the bearings live in a oil bath, i figure there is no reason for them to have grease on them. and i would try to salvage the detroit, just debur it on the out side and take it apart to double check the inside.
Old Aug 15, 2006 | 08:21 AM
Mcmopar's Avatar
That's what was thinking!!
