20 thousandths, right off the top.
Has anybody else done this?
I took my pistons down to the machine shop, and had 'em remove 20 thousandths off the top, and I'm going to run a 20 thousandths thicker headgasket.
Any thoughts or idea's on this?
This will be for my daily driver. About ~400RWHP.
Merrick
Merrick
i would think for a 400 hp street truck you will miss the bottom end power. that will be a pretty good loss of compression. but in laredo i don't think winter starting will be a problem. mike
Mach 4.8's
Mad ECM
PDR Cam
PDR Head
Haisley's Head Studs
J.R. Twins (35-3B)
.020 Head Gasket
.020 Shaved Pistons
SBC FE Conv. Clutch
FASS w/-10 fuel line
We will be grossing up to 40,000Lbs.
What HP do you think this will put out?
With my COMP it did 546 on a 248c Dynojet, but I will be running w/o a COMP now.
Merrick
EDIT: No recoating, just some trick polishing, and dimpling.
Mad ECM
PDR Cam
PDR Head
J.R. Twins (35-3B)
.020 Head Gasket
.020 Shaved Pistons
SBC FE Conv. Clutch
Merrick
Merrick, just curious, how low are you figuring the compression? The commercial engines have pistons down to 15 to 1. They would keep the bowl shaped right instead of the deck lower.
How much is off the head surface? How deep are the valves from the deck?
With a 20 thou over gasket, the low end suffers a bit. Removing 20 thou off the outside ring of the piston is no big deal, but adding the thicker gasket wil lower compression enough to feel it in the lower rpm range.
The stock pistons are cast. They are not hardened on the top.
Don~
Don~
Hey Don,
I'm glad you chimed in here.
I had .010 shaved off my head to get it back in shape.
The valves are factory depth.
HID,
I'm not sure of the C/R. Maybe somebody can help me out here.
I just really wanted to lower the C/R and space the valves farther from the piston, as the pistons were allready makin' love to the intake valves. (.020 or more, since after a .020 shave, there were still some indentions...)
I did not want to buy new pistons, that is why I shaved 'em.
I do not mind feeling less power in lower RPM, as long as this truck pulls good at 2,000-2,800.
Merrick
HID,
Merrick
