20 thousandths, right off the top.
Old May 31, 2005 | 12:42 PM
MCummings's Avatar
Originally posted by Haulin_in_Dixie
I misunderstood Merrick, I though you were trying to lower the compression. A slight drop will not make much difference. Like Don said, a little less torque till it gets boost.
I'm not specificly trying to drop compression, although it is a welcomed side effect. I'm trying to male clearance for the valves.
I know with the turbo'd gassers, you wanna drop compression, and how this truck will be used, (street/strip), I wanted to relieve as much stress as I could. I don't mind loosing 20HP, if the motor will last me 10,000 more miles.
Merrick
Old May 31, 2005 | 08:16 PM
John Rodriguez's Avatar
Tire Hater
Don't you mean, 10,000 miles, period?
Old Jun 1, 2005 | 10:45 AM
MCummings's Avatar
Nope,
10,000 more miles...
I'm trying to build this motor to last at 400rwhp.
Merrick
Old Jun 1, 2005 | 11:44 PM
BigBlue's Avatar
So a total of 11,000 miles?
Old Jun 2, 2005 | 10:11 AM
MCummings's Avatar
Honestly, I'll be happy with 50,000, but if it went more, I'd be tickled to death.
Bottom line is, as long as *I* Break it, it's ok, but if something just wears out, I'll be upset. hehe.
Tyler,
Going to make it to IRP next month?
Merrick
Old Jun 2, 2005 | 02:51 PM
MCummings's Avatar
Here's the piston after getting shaved, and some work with a piece of sandpaper.
Merrick
Old Jun 2, 2005 | 09:42 PM
BigBlue's Avatar
What's IRP? Depending on work (my boss is gonna be grateful enough to give us a week off) and when one of my friends is coming into town I might be able to make it.
Old Jun 3, 2005 | 09:01 AM
signature600's Avatar
Indianapolis Raceway Park...home of the Indy 500.
Coming up in June, and I can't make it. Already scheduled my vacation for that week, but I'm boing to Michigan!!
If it wasn't so far away, I'd drive down, but it's about 600 miles to Indy from where I'm going (but only 135 from home )
Chris
Old Jun 3, 2005 | 06:56 PM
Battering Ram's Avatar
Merrick, about the 20 thou you are taking off. I am curious what results you will have. I'm not shure how much affect squinch clearance has on these motors. It is very important on gassers because it helps prevent detonation. Its one of the reasons most gassers have valve clearances machined into the top of the pistons. I don't think that it is going to cause you any piston bowl problems. Let us know how it runs.
Horace
Old Jun 3, 2005 | 08:43 PM
BigBlue's Avatar
Ahh. There's no way I can make that. I've only got a week off of work and that's already booked solid.
Old Jun 4, 2005 | 10:21 AM
MCummings's Avatar
Horace,
I'm very excited as well.
Detonation isn't that bad on a diesel, compared to a gasser, but it is hard on parts... (My 12v with over 35* had some detonation under 2,000RPM,, )
I read in alldata that my motor has a 16.5:1 compression. If I have -.010 on the head, +.020 on the gasket, and -.020 on the pistons, what would the C/R be now?
I'm hoping with the Mach 4.8's, and Mad ECM, I'll be able to keep the boost low enough to not blow out a headgasket with head studs only, and no o-rings... Think I could do that? (35/14-3B/26)
Merrick
Old Jun 5, 2005 | 10:43 PM
thumper 549's Avatar
Are you guys shooting from the hip??your static C/R not much to do with running dynamic C/R......20 th will hardly do nothing,and if valve clearance is what you want ( I cant imagine you need that much kift with boosted eng.) I suggest a diff turbo set up rather then that high lift.
Gassers need that much lift and duration to get the flow going at high rpm,,,much much high then you CTD will ever see.
Old Jun 6, 2005 | 12:35 PM
MCummings's Avatar
It's a PDR cam, but I think my valve springs couldn't handle as much boost as I was running.
My main goal was to not have to tear the motor down again anytime within the next couple of years.
Dropped C/R, lower EGT's, valve clearances. I don't really care that much, just as long as I don't crack the block, and don't bend a valve.
Merrick
Old Jun 8, 2005 | 04:09 PM
TireHauler04's Avatar
At least you know how to tighten P-Pump Governor Springs down now, right Merrick? by the way..there's a dyno day on the 18th up here ..are you going to make it ?
Old Jun 8, 2005 | 07:24 PM
MCummings's Avatar
Yup.
No problem.
Shut down solenoid diagnostics, and custom "keys",, no problem.
Idle issues? Not there yet, LOL.
I don't THINK that I will make it, but I'll give it a shot.
Merrick
