1/8 drag - let me know what you think
Old Apr 21, 2006 | 07:30 AM
Dan Marino's Avatar
First time I ever raced at a strip.
My best drag:
Reaction .1250
60 ft 2.0618
330 ft 5.1223
1/8 time 8.9900
1/8 MPH 77.82
This was really fun. I felt intimidated the first time up because I was running against a awesome GTO that ran in the 7's.
is there any way to look at those numbers and estimate 1/4 mile time and speed?
Old Apr 21, 2006 | 08:30 AM
lovemysan's Avatar
VERY general rule of thumb is 8.99 X 1.25
I ran 10.40 1/8 and 16.25 1/4.
My ratio is 10.40 X 1.56 = 16.25
At a 1.56 ratio you'd be running 14.02 wich is quick to me.
So for you it would be between 1.25 and 1.5 guessing mathematically. Now let someone who has something similar to you chime in.
Old Apr 21, 2006 | 09:42 AM
mcoleman's Avatar
The 1.56 is fairly close for a lot of trucks. I've ran 8.21 in the 1/8 and a 12.84 on that pass in the 1/4. Not off by much anyway. My easy launches result in 8.32 passes and 13.0s and that ratio says 12.97 so it's close again.
Old Apr 21, 2006 | 09:44 AM
mcoleman's Avatar
You've got a 13 second truck with a harder launch.
Old Apr 21, 2006 | 09:57 AM
Dan Marino's Avatar
I was in 4WD and was holding at 1800 RPMS. Can I launch any harder than that?
When I was in 2WD my times were clear up in high 9's and 10's
Old Apr 21, 2006 | 10:11 AM
mcoleman's Avatar
I launch by my boost gage. I wouldn't go over 10 psi without upgrading the input and output shafts. I broke my output with a 10-12 psi launch in 4X4. Right after I had dynoed 1000 lbs at the wheels. Same day even. I currently launch at 15 psi for bracket racing and higher for trying to get the best numbers. I can pull 1.75 60 foots launching at 15 psi consistently.
Old Apr 21, 2006 | 11:57 AM
purged981's Avatar
This past tuesday I went to our 1/8 mile track and ran. 2nd run I built to much boost and roasted the tires till I let out about half way down.
Old Apr 28, 2006 | 05:44 PM
Cmonroe's Avatar
Don't forget about the flex plate! Shafts are not the only things that break.
Old Apr 28, 2006 | 11:41 PM
Jambbii's Avatar
yes, flex plates they do break as well as everything else that is not supposed to
Old Apr 30, 2006 | 07:31 PM
PeytonMaterne's Avatar
Dan Marino, do you race at kanahwa (sp?) valley? I live in gallipolis. I would like to see you run sometime if thats the case. Is that a "Brian" Vannest valve body?
JWillms81
Aug 26, 2007 11:13 PM
dieselpower04
Apr 12, 2007 12:12 AM
Cummins Freak
Jan 17, 2007 11:29 AM
Hoss
Dec 10, 2005 02:30 AM
