when cold, truck acts WEIRD
Old Dec 15, 2009 | 10:12 PM
nvr-enuf's Avatar
Single digits temperature, after start up, the throttle to actually truck moving is disconnected. What I mean is that you push on the go pedal and nothing happens, then after a delay, the truck may go by itself.
It pulls several codes, unfortunately I do not have them written down in front of me.
Has anyone else experienced this? If the truck warms up / drive 5 miles, the problem goes away.
Supposedly my renter has this same issue on his Duramax / previous chevy diesels.
first time it happen to me, I thought it was bad fuel but it turns out to be repeatable based on temperature (note the truck is not plugged in).
thanks for any advice on what is going on
could it be a frozen battery?
Old Dec 17, 2009 | 12:13 PM
nvr-enuf's Avatar
Truck acts weird at cold start up - Bump
Anyone?
Someone must have had this issue besides me.
If the truck is not plugged in and really cold outside, say single digits, am I supposed to wait and let it idle for some period of time.
The manual in my truck as well as in my diesel VW states not to idle when cold, simply drive it normal.
Old Dec 17, 2009 | 12:58 PM
92'1stGen's Avatar
I would let it idle enough for the oil pressure to build up, and then just give it about a minute to get itself together until the engine idle smooths out. After that you can go ahead and go because it's not going to make any heat or what not while it's just idling. Also at the same time, put the transmission in neutral. This will allow the fluid to circulate through the transmission and fill the torque converter properly before you put in Drive.
As far as the pedal issue, I've had instances where there is a slight hesitation in the throttle when cold, but yours sounds like it's of more magnitude. Does it have a lot of lag or just a slight bit. Your problem could possibly be solved by doing what I mentioned above about putting the transmission in neutral while it's idling for that little bit before you go. If you don't do that, and then just drop the shifter in drive, then the torque converter isn't able to properly "bite" on the shaft in the transmission and it might give you a slight hesitation or shudder.
Old Dec 19, 2009 | 10:33 PM
Kilroy's Avatar
This is my second winter with the truck. Last year it didn't, but this year it developed a hesitation off idle till really warmed up. I has also become harder to start when really cold. Hesitation and hard starting seemed to start the same day. Any idea of reason? I picked up some fuel system additive but haven't driven much yet with it.
Old Dec 21, 2009 | 01:49 PM
Lost Lake's Avatar
Don't take it to Dodge, they'll have no idea why it happens...
The transmission pump doesn't operate in park. Either start your truck in neutral or put it in neutral right after you start it. Let it idle 20 seconds in neutral and you'll build tranny pressure and it will go immediately.
Old Dec 21, 2009 | 07:58 PM
nvr-enuf's Avatar
I would say the lag is 5 to 7 seconds, sometimes even nothing.
I will try the neutral idea
Truck will pull several codes - probably still stored. I will check the strength of the batteries this week
Old Dec 21, 2009 | 08:21 PM
nvr-enuf's Avatar
The codes I get are P2121, P2123 and P0514
Any suggestions in what it could be or simply that I need to let the truck idle when really cold
thanks
Old Dec 21, 2009 | 09:20 PM
kokalit's Avatar
thanks
P2121 = Throttle/Pedal Position Sensor/Switch "D" Circuit Range/Performance
P2123 = Throttle/Pedal Position Sensor/Switch "D" Circuit High
P0514 = Battery Temperature Sensor Circuit Range/Performance
Sorry, can't help any more than that.
Old Dec 21, 2009 | 11:39 PM
OCMerrill's Avatar
You need a new throttle position sensor. 04-1/2 should be on the foot feed.
That should cure it.
Old Dec 22, 2009 | 09:16 AM
Lost Lake's Avatar
+1. Let us know.....
Old Dec 22, 2009 | 12:18 PM
nvr-enuf's Avatar
why only when it is cold?
By not replacing, what is the down side
Truck is fine as long as it warms up
Old Dec 22, 2009 | 04:32 PM
OCMerrill's Avatar
Eventually it will dead pedal you. For me it was right in the middle of a busy intersection. Fun stiff.
The codes you posted are APPS codes. To cure the codes you need to replace the TPS and they are spendy.
Old Dec 23, 2009 | 07:13 PM
gwbrehm's Avatar
I had the same problem with my early 04 3500. I pulled my hair out trying to figure it out and initially ruled out the APPS because it only happened when cold and went back to normal once the truck warmed up. It also ran perfect all summer long without any incident. Mine gradually got worse during the cold months and would leave me on the side of the road with a dead pedal several times before finally warming up. I tried everything including disconnecting my heater grid with no luck. Not believing it would correct my problem, I replaced my APPS with one of the ones available through Timbo. I figured I would at least eliminate it as a possible cause of my problem. To my surprise it fixed my problem thus far, even when it was down to 29 degrees. The only thing I can think of is that the cold temperature causes something inside to expand or seize and thus malfunction, once warm the APPS returns to normal. I hope this helps
Old Dec 23, 2009 | 07:19 PM
Lost Lake's Avatar
You guys are a gold mine of information!!! Cheers to all of you!!
idagrizz
Nov 12, 2011 05:00 PM
440_D50
Sep 8, 2008 09:35 PM
Bobcat698
Apr 27, 2007 04:46 PM
Ridiculous
13
Jan 29, 2006 08:56 PM
AviatorOne
Dec 15, 2005 06:46 PM
