what can my truck handle???
Old Oct 18, 2012 | 09:31 PM
Rocky-12valve's Avatar
my plans are to throw a set of twins on my dd 92 reg cab(truck in sig) what i want to make sure is that my truck will be able to handle the power and still be reliable. trucks is and will remain my DD. i came across an ht3b 75/83/23 turbo for cheap so that is what i was gonna use with my current turbo. let me know what you guys think open to any help thanks, id rather not learn these things the hard way...save me some money.
Old Oct 19, 2012 | 09:07 AM
enafzige's Avatar
It depends how built your tranny is. If you're still running the Dana 70 rear end, that's next on your list to explode. You might start looking for a Dana 80. Other than that, it sounds like you should be good!!
--Eric
Old Oct 20, 2012 | 11:14 PM
Thumbs up
already got the dana 80 in the rear...what about the intercooler? i blew a pretty good size crack in it with the single HTT wastegated at 45psi...welded it back up and it seems to be holding up pretty good.
much appreciated!
Old Oct 20, 2012 | 11:49 PM
BILTIT's Avatar
Get a powerstroke IC, its been done alot and they have held up.
Old Oct 21, 2012 | 02:35 AM
how much can i pick one of those up for usually?
Old Oct 21, 2012 | 04:28 AM
and what about the 2nd gen i/c compared to the powerstroke i/c
Old Oct 21, 2012 | 09:31 AM
BILTIT's Avatar
i got mine from a wreckers for 150. The PS IC will fit easier than the 2nd gen in a IC truck. The 2nd gens work well in the non-ic trucks.
Old Oct 21, 2012 | 11:43 AM
92betsy's Avatar
Get the PS IC from a 99-02 I believe is the years. They don't have the plastic ends on them so they can handle more boost.
Old Oct 21, 2012 | 04:01 PM
thanks fellas...what about intrecooler piping? do they use the same size?
Old Oct 21, 2012 | 04:31 PM
BILTIT's Avatar
They are larger, 3.5''. You can get 3'' coolertubz with 3.5'' ends to fit mate with the ps IC below, just scroll to the bottom.
http://www.coolertubz.com/
Do a few searches and you will find everything you need.
Old Oct 21, 2012 | 10:44 PM
jimbo486's Avatar
The PS I/C has 3.25" charge ports.
Old Oct 21, 2012 | 11:35 PM
BILTIT's Avatar
Woops, my bad. I new they were bigger than 3''.
Old Oct 22, 2012 | 12:30 AM
awesome thanks for the help. ill have to go see what i can find! even if i dont end up doing twins this sounds like a good idea lower some egts maybe get better mpg...doesnt see too expensive either
Old Oct 22, 2012 | 12:47 AM
other thing i forgot to add is i have a tranny cooler mounted in front of the intercooler. how much bigger is the powerstroke i/c? think its gonna give me a problem?
Old Oct 22, 2012 | 07:24 AM
BILTIT's Avatar
Do a search for peoples installs, cooler shouldnt be a problem.
jukenut
Sep 22, 2012 01:03 PM
Totallyrad
Jul 19, 2011 07:41 AM
wayne74447
Jul 11, 2006 01:54 PM
finallydiesel
Jan 6, 2004 04:39 PM
