Big Rigs Talk about other Cummins powered vehicles here. As a matter of fact, it doesn't even have to be Cummins, but it will be diesel! :)
n14 select
Old Jan 16, 2015 | 09:45 PM
NE frmhnd's Avatar
n14 select
We figured out a while back if it started misfiring, drain the fuel heater/prefilter. Started that Wednesday, no help. Pulled the NAPA 3115 and spun on an FS1000. Truck ran like it's never run before. For 2 miles. Back to misfiring, and not clearing up. Cleaned the screen in the fuel heater (Donaldson) today and no change.
I don't like that truck.
Old Jan 17, 2015 | 09:20 PM
pind's Avatar
What's going on with the weather where you are?
Old Jan 29, 2015 | 10:36 PM
NE frmhnd's Avatar
It was in the 40s or 50s and had howe's in the fuel.
Had a few days in the 60s and when the boss fired it up to go to the shop it misfired all the way in again.
Hopefully it'll be fixed when it comes back.
Old Jan 30, 2015 | 11:16 PM
pind's Avatar
Ok, we had a t800 that sat for over a year with 1/4 full tanks. So every turn in the weather, it was sweating buckets in there. Ended up giving us fits til I got the whole story. Drained the tanks, heated them to boil off any residual water, then new fuel and filters, no more problem.
Another thing to note, on an n14, there is no filter between the tank and the inlet check valve. So crud can get sucked into that valve, and cause all sorts of issues. Get a filter head mounted on the frame, that takes an fs1000, same as the engine, no more problems.
And... just ahead of the fuel tank, above the right step, there is a plastic shroud/wrap around the hoses, if the tanks are mid mounted. Under that wrap is a fitting, female to male, on both supply and return. I have seen this fitting come loose on the supply side, and cause headaches that would make a Billy goat puke.
Good luck
Old Jan 31, 2015 | 06:47 PM
NE frmhnd's Avatar
There's the screen in the fuel heater, and an fs1000 inside the frame. No filter on engine, unless it's some sort of flat cartridge deal.
Old Oct 13, 2016 | 09:31 PM
NE frmhnd's Avatar
The fuel pump burnt up in this truck this spring. They kept running it like that after I left.
Run 'er til she blows, then get mad at whoever is driving it. Glad I no longer work there.
the_fox_man4
Oct 24, 2006 09:22 AM
4x4dually
32
Oct 3, 2006 08:24 AM
Igor
Nov 4, 2005 01:03 AM
winner172
Jun 9, 2003 07:17 AM
NWDave
Nov 16, 2002 09:40 PM
