Big Rigs Talk about other Cummins powered vehicles here. As a matter of fact, it doesn't even have to be Cummins, but it will be diesel! :)
Ford F500 Electric Brake Motor Problem
Old Apr 17, 2011 | 08:13 AM
Stamey's Avatar
I have a 1996 F500 with a 6BT in it. Everything was fine but I haven't driven it for a few months. I fired it up Friday night and the electric brake motor light was on, as well as the Brake light. Usually these cut off pretty quickly, but Friday they stayed on. I could hear the motor running under the hood.
I see no problems with the brake fluid level, but the pedal is hard, even when the engine is running.
I have not dealt with this type of braking system, with an electric motor backup on the hydro-boost. Does anyone know what's going on, what to check, or where I can find more information on troubleshooting this?
Thanks,
Chris
Old Apr 17, 2011 | 12:32 PM
Hvytrkmech's Avatar
Does the power steering work? Check the fluid level and condition. There is most likely a power steering filter in the p/s reservoir make sure it is not plugged up. FYI the power steering pump also operates the power brakes.
Old Apr 17, 2011 | 07:23 PM
Stamey's Avatar
Yes, PS is fully functional and the fluid level in the remote reservoir is full. I figured that if the PS was working I wouldn't need to worry about brakes because it looks like a normal hydro boost, just with an electric motor attached to the bottom. That's another odd thing. I'm guessing that the electric is a backup, if the engine stalls, but the brake pedal is hard now even with the engine running.
Thanks,
Chris
Old Apr 21, 2011 | 07:19 AM
Hvytrkmech's Avatar
Yes sir the electric motor is a back up and should come on anytime you touch the brakes with the engine off. Is the electric motor running with the engine on?
I would pull the return line and run it into a bucket to see if you are getting adequate flow, also flush the system out. If you have good flow then suspect a faulty hydra boost. I would also disconnect the brake pedal from the rod and to make sure it is not seizing up from sitting.
Old May 10, 2011 | 04:02 PM
Stamey's Avatar
Sorry, I missed that you had replied again to this thread. I looked at it some more and now I feel stupid. It turns out this system has two different circuits, one for the PS, driven off of the timing case, and one for the brakes, driven by a belt-driven PS pump. Two great big reservoirs, one mounted beside the radiator and one over the engine. I checked the one over the engine and added PS fluid and now the brakes act right again.
I plead confusion. Even with two circuits this sucker has a maze of hoses and fitting blocks so I can't really tell what's going on under the hood.
Thanks for the help,
Chris
Old Sep 17, 2011 | 03:25 PM
Santaclaus's Avatar
You need to find the leak. If it was working correctly when you park it. Just my two cents, Mike.
Old Sep 19, 2011 | 09:17 AM
Stamey's Avatar
Yes, the leak will be hunted down if it happens again. I have had the truck for 3 years now, and this is the first time I had it get low. I do not know what the fluid level was when I bought it because in my confusion I did not think to check that reservoir. I only checked the one that is suspended over the engine.
I will be keeping an eye on it though, in the every 6 months I drive it.
Thanks,
Chris
Diesel Girl
18
Oct 6, 2013 03:03 PM
cj5er
Dec 20, 2009 09:19 PM
Stamey
0
Jul 26, 2009 09:35 PM
Marine
Oct 22, 2005 11:43 AM
