Changed compressors and now i have issues?
I changed compressors in my 98 T800 in my sig, it was getting old and starting to leak so it was just time, however now after I got it changed out it builds air like it is supposed to, cuts out when it is supposed to, but when it looses a wee bit of pressure (down to 110-112 psi) it sounds like i have a good size air leak under the hood that last approx 2 or 3 seconds, then it stops making funny noises and then a couple seconds later the compressor cuts in and runs up to 120-125 psi where it cuts out again. I dont know whats causing the air leak sound im hearing or where its coming from because i cant get it to duplicate these issues when its sitting still..... I will try it later today at 1200 or 1300 rpm to see if it will do it again for me, I didnt change the Governor or pressure relief valve when i did the compressor.... unsure what to try over the weekend but i will try to diagnose and fix on tuesday..........
Any suggestions?
Thanks guys
Any suggestions?
Thanks guys
Could be the governor, they are less than $30.00 here. It could also be a lazy discharge on the air dryer. Let us know when you check it out later.
Yes, with the engine running wait by the air dryer. When it spits or discharges see how long it takes to shut off. If it does not shut off immediately after discharging push up into the center of the discharge hole with you finger to reset the valve. If that works you can remove the lower valve assembly dismantle it on a bench the clean and lube it. Do you have a scew on filter on your air dryer? If so you should replace that as well.
Ok, I installed a new Reman Bendix Air dryer and governor (for the $18 i wasnt going to not do it anyway) and it still has a lazy discharge, when i push up on the valve to reset the old fashioned way it will stop but it seems to have the same discharge at approxametly 115 psi that the old dryer-governor combo had although this one is a lot shorter of an event and doesnt seem to cause the compressor to cut back in......going for a drive later tonight to see what happens at speed and will advise
ontheedge
13
Apr 1, 2008 04:59 PM
TJE
Oct 2, 2006 09:59 PM
silverram323
Oct 10, 2003 12:19 AM
