Big Rigs Talk about other Cummins powered vehicles here. As a matter of fact, it doesn't even have to be Cummins, but it will be diesel! :)
855 question
Old Sep 6, 2010 | 03:02 PM
G1625S's Avatar
Almost greenish on the stick. Not quite milky, but on its way. I'll post up a pic shortly.
Old Sep 6, 2010 | 11:40 PM
1-5-3-6-2-4's Avatar
liner oring. sounds like. when you drop the pan, pressure tester on the rad cap, find the coolant tract marks. inside the block.
Old Sep 7, 2010 | 06:14 AM
G1625S's Avatar
Can I replace just the o-ring or do I have to replace the liner as well once I press it out?
Had another old school wrench listen to the truck last night and he said they'll run forever sounding that way, so I'm a little more optimistic Thanks again for all the replies. Gonna try and pull the pan in the nexy couple days.
Old Sep 7, 2010 | 06:20 AM
Hvytrkmech's Avatar
Yes you can change just the o-rings. the only issue is that when you push the piston out of the liner the rings usually break, so be ready to do more work to it. I use vegetable oil on the o-rings when I set the liners back in.
Old Sep 7, 2010 | 08:38 PM
truckwrench1's Avatar
just a thought do you have an injector or 2 maybe stuck when tou ran the overhead what sequnce and torque on injectors talking about compression release these are not touch and back off injectors and in my experience plain engine oil works just as good as veg oil also when pan of check end play on crank and deffinently pressure test with pan off. (i also remember cummins revising the overhead set process so make shure u used the correct one)
Old Sep 27, 2010 | 03:39 PM
G1625S's Avatar
Well, I've had some time to think about this. No time to do anything, just think I'm gonna try and shop around for a used big cam as they seem to be pretty reasonable and I could pick up a few much needed HP. It's gonna be faster and darn near cheaper to stab an engine than it would be to tear into this one again. The mil-spec stuff is pretty well limited to the oil pan and coolant purge tank, so any old class 8 engine should pop right in. Thanks for all the advise.
G1625S
Nov 21, 2010 11:58 AM
morkable
38
Aug 5, 2007 11:35 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
