Big Rigs Talk about other Cummins powered vehicles here. As a matter of fact, it doesn't even have to be Cummins, but it will be diesel! :)
02 FL80 question
Old Jan 9, 2010 | 10:02 AM
kthiemann's Avatar
02 FL80 question
Maybe this belongs over in the 24v section but thought I might start here first. Am in the process of replacing the vp44 on an ISB that is mounted in a 02 FL80 and noticed something wierd. When I took the old pump off instead of a overflow valve on the return line there was just a normal banjo bolt and of course the new pump comes with a overflow valve so my question is this.....do I use the overflow valve or the reg. banjo bolt? I can't decide quite which way to go this time. Thanks for any thoughts ya'll might have.
Old Jan 9, 2010 | 03:48 PM
1-5-3-6-2-4's Avatar
so your saying there was a regular banjo bolt in the inlet and outlet?
If so, I bet thats why you're changing the VP right now
it has to have an overflow valve in the VP outlet. no matter what application the engine is in.
Old Jan 11, 2010 | 10:22 PM
Monty's Avatar
Follow the return line to the back of the engine by the firewall. My bet is you have a "tee" in the return line with one section holding your check valve. Many year models used this setup.
Old Jan 12, 2010 | 06:24 AM
kthiemann's Avatar
Monty hit the nail on the head, on this set up the overflow valve is located at the junction block where the return lines come together at the back of the head....I just didn't see it.
Old Jan 12, 2010 | 07:29 AM
Hvytrkmech's Avatar
That is where I found mine on our Sterling.
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
