ABS pump help
Old Jul 8, 2010 | 10:23 PM
shaft's Avatar
ABS pump help
My ABS pump will not stop running even after the engine is shut off. I had to pull the ABS fuse to make it stop. Is there anything I can do to fix this issue? Or does it need to be replaced? Any ideas how much it would cost for a replacement? Any tips and suggestions are greatly appreciated.
Old Jul 10, 2010 | 06:22 AM
TOM R's Avatar
I asked the same question with the same problem a few days back with no reply, think the pump is around $500 guess you got to buy the whole assembly, and only from salvage or the dealer, also only fits 1 ton if I remember correctly (had a yard look it up)
Old Jul 11, 2010 | 12:55 AM
TopperHarley's Avatar
Same thing happened to me almost two years ago. Was driving home from work one day and suddenly got brake light and ABS light. When I got home and shut down the truck the pump kept running and I had to pull the breaker to get it to quit. Been that way ever since. Took it to the dealer for some other stuff and had them diagnos it while I was having the other work done. Turns out, at least in my case, that the CAB (Controller Anti-Lock Brakes) went out. It's easy enough to replace, just plug a new one in. Only problem is the thing costs an arm and a leg. One of these days I'm going to get off my *** and hit up a junkyard for one.
~Topper
Old Jul 11, 2010 | 08:12 AM
shaft's Avatar
Yep. Called the dealer yesterday and they want $1000 for the pump and the electronic part ---- they said I have to replace both if one breaks. I guess I'll be hunting for one in the boneyard.
Old Jul 11, 2010 | 01:15 PM
$1000 sounds about what they quoted me, but they never mentioned having to replace the pump, just the controller. I don't see why you'd have to replace both.
If you find a boneyard that has more than one, shoot me a PM. Can't find any near me.
~Topper
Old Jul 11, 2010 | 06:34 PM
TOM R's Avatar
i got a friend in that buisness and the crooss reference says only fits 1 ton dodge (I have a dually) mine has a computer on the pump are we talkin about the same thing or is there an additional one in the cab?
Old Jul 12, 2010 | 08:12 AM
shaft's Avatar
Yep. We're talking about the same thing. The electronic stuff on top of the pump under the hood.
Old Jul 14, 2010 | 11:35 AM
shaft's Avatar
Found a guy in my neighborhood that has a 1998 12V Dually that he's parting out and still has the ABS pump and module in the truck.
Does anybody know if this pump will work on my 1999 Dually?
Otherwise, where or who can I go to to get the info from?
thx
fitzydog
21
Oct 11, 2017 12:09 PM
DodgeRam24V
0
Jan 7, 2012 06:02 PM
BigBore050
Mar 9, 2010 11:46 PM
sssmaly
Jul 13, 2007 12:57 PM
mr T
Feb 24, 2007 06:42 AM
