View Poll Results: Which date is best for a spring dyno at AFI
April 11
5.00%
April 18
10.00%
May 9
20.00%
May 23
13
65.00%
Voters: 20. You may not vote on this poll
Spring Dyno at AFI Edmonton
Old May 17, 2009 | 10:48 AM
  #166
StealthDiesel's Avatar
Originally Posted by Tate
Are you driving 80 the whole way?
Leave at 7:40 to get there by 10 from Crossfield.
lol.. Ok ok!! I'll put my purse down & drive a little faster.
How about we meet at the Crossfield Timmy's at 7am & then be on the road by 7:30am?
Tough crowd!!.. Joe
Old May 17, 2009 | 01:30 PM
  #167
morkable's Avatar
lol,, very tough! I will pushing it close too, I am leaving my home right around 6 am,, so I will be getting there around 10ish, so if am a couple minutes late dont send out the search parties
Old May 18, 2009 | 01:09 PM
  #168
kennyblatz's Avatar
haha 63 moves fast enough i cam down a hill at 180 slowed up to 160 after the hill and 3 cars pasted me i guess i was holding up traffic
Old May 18, 2009 | 02:38 PM
  #169
morkable's Avatar
I dont go that fast anymore on there,, too many sherrifs. And I just got a letter from the govt, saying I should slow down too
Old May 18, 2009 | 02:49 PM
  #170
Doj Dewd's Avatar
meet at 7am sounds good to me. just enough time to grab a quick something at Tim Horton's and be on our way by 730am.
i'm looking forward to the looks on people's faces as a convoy of dodge diesel trucks rolls by on the QE2!!!
Old May 18, 2009 | 02:53 PM
  #171
03 ant a hemi's Avatar
You guys will be rolling through Red Deer around 830 ish then?
Old May 18, 2009 | 03:58 PM
  #172
Mike Holmen's Avatar
The Guru
I'm still running the dyno. I'm in for the free super. I'll bet 435rwhp, mines stock, so I should be close.
I might get a few more to come. I might have three to four more guests, that may or may not run the dyno.
Old May 18, 2009 | 04:04 PM
  #173
ram4by's Avatar
Any volunteers to help me swap injectors in the parking lot before I pull?
Can't get to the truck until then...
I rigged up a home made slide puller yesterday but need a deep 24mm or 15/16 socket..
I probably heve wrenches for the lines in the truck....
Old May 18, 2009 | 05:06 PM
  #174
morkable's Avatar
Ill bring some sockets with me Steve
Old May 18, 2009 | 05:45 PM
  #175
ram4by's Avatar
Thanks Dude,
but I might be done by the time you get there! LOL.
Take your time on that highway.....
I'm gonna try to make it there the night before as I'll have the kids with me I hope....
Last time injectors were done I was handing the wrenches to Wildcat Rod so I'm sure I could do it by myself if I had to.
Old May 18, 2009 | 05:49 PM
  #176
Diesel Dave2's Avatar
Pickin on the wrong admin...
Did you know that if you have a flat on one of the duallies you can't tell...Was at Canadian tire today and for some reason I decided to check all my rear tires...One inside dually tire was completly flat...Wonder how long I was driving with that flat....Stupid screw is stuck in it...
Old May 18, 2009 | 05:55 PM
  #177
ram4by's Avatar
good point. I'll check em before I hit the highway as the truck sits for weeks between uses...
Old May 18, 2009 | 06:07 PM
  #178
morkable's Avatar
What time do you fly in Steve?
Old May 18, 2009 | 06:15 PM
  #179
Tate's Avatar
I can give you a hand. I used wrenches for taking the hold down nuts off, just need a good bar (ended up using a crescent wrench) to pull them out. Fred knows how to change 12v injectors as well.
Old May 18, 2009 | 06:51 PM
  #180
ram4by's Avatar
Ok, thanks Tate.
Just thought it'd be good to get exactly 44 lbs on the nuts so they don't leak. I'm draggin my torque wrench, anti-sieze, puller, install kit and, of course, injectors with me...
Was also thinking of bringing a hand grinder to attack the AFC foot but on second thought may just install the hr 370's first then check smoke and adjust the smoke screw and star wheel if it needs more fuel off the line....
Hopefully this could be done on the dyno at the time as it would only take a sec. Then pull again.
If it needs that plate I ground up dropped in I may do that too, off the dyno.
I also have here a couple of small springs that turn a 3gsk into a 4 so, Tate, how hard is it to keep the revs under 3200 with a 4gsk? Think Martin can do that easily?
My last dyno graph had peak torque at 2750rpm. If I installed a 4gsk but only spun it to 3350 like the last time would that move my peak torque down the rev range, say to 3000rpm?
While I think of it Tate, if Martin rolled in slower on your white dually would that have moved your torque peak further down the rev range resulting in more hp?
Was your Nov. 2007 pull done with a 4K gsk?
Kev: should touch down about 6 then grab a hack to take me to my truck....
Hopefully grab the kids at the ex's place without incidents and hit the highway by 7 !
S.
