so help my tune my next set of twins on paper
Old Sep 29, 2009 | 11:15 AM
winkdemon's Avatar
oh sweet there a nice machine , used one a bit , the one i used alot was a hobart 350 i think it was old one , worked well tho
Old Sep 29, 2009 | 04:48 PM
1-5-3-6-2-4's Avatar
Originally Posted by dvst8r
I can weld it.
But can you use paint and draw it, I have a tough time visualizing things like that.
I am going to try and get this. You are going to cut off the current "air filter ring" and then we will weld in a new piece that is the same diameter as the inducer. This will connect to the rest of your charge pipe via V-band clamp?
If that is the case, I like that idea, as I really think it will help to keep the velocity up. Vs going 3" and right at the turbo stepping it up to 4"
thats exactly the idea. but. I don't neccissarily want to cut off the big air filter ring. as then I could never really use it as a single after that. but thats the idea of it. I think it's be far more efficient cramming air directly into the inducer via a smooth transition into the inducer. NOT like all the rest are creating huge turbulence at the inducer of the secondary when the primary hits.
this is all just my speculation of what I know about hydraulics. I'll have to sit down with the brains and put my engineer hat on and figure out how to get that in there with out permanently damage.
I'm thinking cut the air filter ring off cleanly. thread some large NPT threads on the OD of the inducer. have adapter cone cut with matching FNPT threads. master tig the filter ring back on the compressor housing. now there can be adapter or no adapter in 30 seconds with a pipe wrench.
I don't know anything about paintshop photoshop junk. so picture it a nice 6-8" long gentle taper from the pipe size to the inducer size. whatever the actual dimentions are doesnt really matter right now. just getting the theory down.
Old Sep 29, 2009 | 05:44 PM
dvst8r's Avatar
LOL, all I can picture is shoving a 3" OD pipe in there, welding it up, and then taking a die grinder to smooth out the transition.
But that would require cutting off the air filter flange... Though your idea of threads is very intriguing.
Old Sep 29, 2009 | 08:08 PM
Jeff K's Avatar
Luke, I think I have some 3.5" mandrel bent cold air piping elbows (new) that I bought for my last set of twins. If you want it, let me know.
Jeff
Old Sep 29, 2009 | 08:25 PM
jeff coolio. 3.5 would be better. thats what the IDs are actually. when you're free, I'll come over. i'm free all day tommorrow.
Old Sep 29, 2009 | 09:02 PM
Mike Holmen's Avatar
The Guru
I would leave on the compressor inlet flange. Its better to go in straight that have a bend, even a slight one. It evenly loads the impeller. The inlet is designed to provide the first transistion, do a little work to compressor the air. You do major changes, you could effect the performance of the compressor (I would guess that you would loose efficency and some of your pressure ratio). If you look, there is a tapper part, silencer ring, that guides the air into the eye of the compressor. The only thing better would to pre-swirl the air, kinda like inlet guide vane, using the air velocity to start the process of going into the compressor impeller.
Ideally you try to get the air to be as straight as possible going into the compressor. They call that laminar air flow, which the opposite of turbulent. You would be supprised on how much engineering goes into the inlet of the turbo. Also there is anti-surge bleed ports just under the silencer, basically it feeds pressurized air from the impeller tip back into the impeller eye. You can try it and see what happens, but thats my two cents.
Old Sep 29, 2009 | 10:05 PM
Mike theres no bends in my plan. I know laminar - same as hydraulics. thats why I want to do what I want to do.
I need to show you what I mean.
that silencer ring is not good enough IMO. its too steep of an angle.
and I get all the engineering that goes into this junk, but none of tht engineering is for pressurized air in. its based on an intake vacumee right. filter restriction factor. no engineer accounted for pressurized air going into the inducer i will bet on that.
So I think all the wizz bang thats engineered into the upside of the compressor is moot. because the intake side of the compressor housing was engineered for a different atmosphere than it sees in twins.
Old Sep 29, 2009 | 10:10 PM
dvst8r's Avatar
So I was doing some reading on a tractor forum, and the general consensus there was 3" is the best bet, as they were saying keeping the velocity up, was better then the extra flow + sizes offered. This was even on some pretty big turbos.
I have always read, and done, go with the size of the primary outlet, but I also know that tractor guys have put way more $$$$ and time in then anybody in diesel performance... So now I'm just confused. I truly wonder if a person, or even a dyno would notice the difference if that is all that was changed...
Old Sep 29, 2009 | 10:47 PM
Lil Dog's Avatar
Would this tapered cone be similar to the TAG that I have??
Old Sep 30, 2009 | 12:16 AM
I suppose that TAG item is going in the right direction. but still thats only about an inch long by the looks of it? and I think the more major point to that item is the honeycomb in it.
see what i'm getting at is to transition from the 3 or 3.5 pipe to the inducer size over say a 6-8" length cone. to direct all the flow out of the intermediate pipe directly at the inducer. WITHOUT haveing the major turbulence created by that cavernous space that houses the inducer.
Old Sep 30, 2009 | 08:38 AM
The Guru
At work we have compressor that you can adjust the guide vanes angle forward and reverse. The guide angle help guide the air into the compressor, try to straighten out the air flow. You would be supprised how tuberlent that the air flow is the front of a compressor. I was thinking about copying some of my compressor text theory info and posting a PDF, some of the theory.
I'm not saying that it wont work, just stuff to be aware of. The same goes for the compressor housing, its job is to direct the air out of the impeller and finish off the last velocity leaving the compressor. The compressor housing machined surface that mates sorta up with impeller, has a tight tolerance. If you have to much clearance, air will not travel up to the tip and you'll be recycling air inside the compressor housing. Thats why gas compressor used shrouded impeller not open faced impellers. Thats my 2bits of compressor theory.
Blake Clark
21
Aug 21, 2012 12:35 PM
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
highrpms
Mar 16, 2008 08:35 PM
