slave cylinder setup
Old Feb 21, 2010 | 04:10 PM
BustedWrench's Avatar
Hey guys,
Hope it's not out of line, I posted basically the same q' in the 12valve forum and I'm getting zero response. I know a couple of the Alberta guys have installed SB dd clutches--is it normal/ok to have to push the slave cylinder pushrod deeper into the piston when you install it? My pushrod sticks out over 3" and the seat on the arm is only an inch or so inside the hole--seems like that would cause the release bearing to be spinning all the time? or is that normal with a hydraulic release system?
Old Feb 21, 2010 | 05:50 PM
Tate's Avatar
Its normal. The amount of force to push that rod inside the cylinder vs. what is needed to actuate the clutch is huge.
Old Feb 21, 2010 | 07:58 PM
Thanks Tate so does that mean that the throwout bearing is spinning all the time then? with that pressure against the throwout fingers?
Mechanical linkages I've always set up with just a bit of slack to avoid burning up the throwout bearing--obviously the size of the bearing and the RPM's with this engine are both in the bearing's favour
Gen414
May 7, 2009 11:08 AM
cgmorgan06
Nov 15, 2007 04:02 PM
Wulzcat
Sep 14, 2007 08:37 PM
Heeler00
Feb 18, 2004 01:52 PM
Strange
Jan 24, 2004 06:45 PM
