setting the Valves Hot or Cold Does it really make a difrence
Old Oct 7, 2010 | 09:44 PM
roxxx's Avatar
Just curious I really have a bad tick hopefully its just Valve lash but was curious on doing them Hot or Cold ? I know the manual reads to let sit 4 hours
Old Oct 7, 2010 | 09:55 PM
ccmckee's Avatar
Should be done cold the heat can make a bit of difference on the clearance. Most folks set them 2 thou tighter than spec anyways.
Old Oct 7, 2010 | 10:16 PM
1-5-3-6-2-4's Avatar
long as the engine has had some time to equalize the heat you're good to go./
Old Oct 7, 2010 | 10:48 PM
roxxx's Avatar
thanks guys
I will hopefully be able to do it but , I may not have time. so might have to get a shop to do it. that's the reason i ask. Just how long it has to sit if its driven
Old Oct 7, 2010 | 11:24 PM
highway tractors come in off the road all the time direct for a a tune up. theres no time for sitting to cool off. time is money. I've had some so hot you couldn't actually touch the rockers or jakes you'd get burnt. so you kind of hover.
Old Oct 10, 2010 | 08:25 AM
NoSparkplugs's Avatar
Every engine manufacturer I've seen says to set them cold BUT like 1-5-3-6-2-4 said, sometimes a cool down isn't an option. I set my 04's valves earlier this year when it was still pretty warm, just didn't have all night to let it cool down. I gave it a couple of hours to cool so wasn't at operating temp but still fairly warm. I've yet to have a problem and that was 20k kms ago. I will say that after setting them my fuel economy picked up a fair bit, like 50-100km a tank. Blew me away how much it would affect it.
Old Oct 12, 2010 | 11:20 AM
Lil Dog's Avatar
I think our "cold" would be a lot colder than a shops "cold" I'd say anything less than operating conditions should be cool enough. Just stay consistent. On the small geometry of the B engine I bet the difference wouldn't be much. I like the warmer oil as it tends to be less of an issue getting feelers in there.
Old Oct 13, 2010 | 07:47 PM
roxxx's Avatar
Thanks Again guys I finally had a moment to talk to a local shop that I trust ,he said nope he wouldn't do them warm so I am pooched. Was really hoping to get them done before the Armour Dyno lol I haven't even got my 4 inch exhaust on yet arghhh . I have being just to darn busy It rains it pours Oh well thanks again for the input
Old Oct 13, 2010 | 08:43 PM
krh's Avatar
krh
I'd set em warm. I've done a valve set on a machine smoking hot, then about a week later it was brought into the shop so i checked them after it had cooled off and none of them needed adjusting. Its just valves, one or two thou arent going to make a difference.
Old Oct 14, 2010 | 09:57 AM
Tate's Avatar
Cummins has a large tolerance on valve lash. .007-.015 on the intake, and .015-.030 on the exhaust. Get a set of feelers and a screw driver and set them. Its far from rocket science.
Old Oct 14, 2010 | 09:58 AM
dvst8r's Avatar
Originally Posted by Tate
...It's far from rocket science.
Closer to rocket surgery.
krazydher
25
Apr 15, 2010 12:37 PM
BossHogg
25
Feb 27, 2010 11:53 AM
Common
Apr 24, 2007 05:05 PM
Dodgezilla
Jun 11, 2004 01:28 PM
