May have burned motor up ?
Old Nov 2, 2010 | 10:42 PM
Tate's Avatar
Roxxx, Yes I do, but... I'm using it, sorry buddy. Sorry for being a tease.
I'll grab it and take few pictures showing the differences between all the different years. I have a 2wd VE engine buildup that on going. I'm using a manual shift RE48 on that engine.
I've been meaning on doing some checks on different block designs that I have to see what matches up and/or doesn't.
Been also wanting to see what it would take to throw a P7100 onto a 6.7L
Notice that the stock 6.7L flex plate is a solid piece.
AFAIK, you need a 2nd gen adapter if you're running newer flex plates and trannies. I know thats the case for putting a NV4500 a 1st gen. I'm sure Rob knows if the 1st gen stuff will work with the 47/48 trannies.
Old Nov 3, 2010 | 08:43 AM
Mike Holmen's Avatar
The Guru
Roxxx, have you taken the truck apart? Post some pics of the carnage?
I agree, contact Rob, he probably has a few laying around.
I know for this 02 grey truck I'm putting together, its getting the stock 24V flex plate. So far its not cracked, and/or broken, yet....
Old Nov 3, 2010 | 09:23 AM
roxxx's Avatar
nope not yet scrounging for for parts as of now ... LOL we took the bottom inspection plate of and pieces fell out and there is shavings. Looks like it went through a cheese grater
Old Nov 3, 2010 | 10:04 AM
B-North's Avatar
It's an upgrade to run a 2nd gen flexplate in the 1st gens. Any flexplate from a non 6.7 will work not sure if the 6.7 works or not. The 1st gens are thinner and break the hub out. A new one is only about $150 from cummins (not dodge).
Tallguy67
May 11, 2014 12:35 AM
madhat
May 26, 2007 10:58 PM
Bart Timothy
May 4, 2006 04:53 AM
dss667
Sep 5, 2004 11:24 AM
