May have burned motor up ?
Old Oct 28, 2010 | 10:17 PM
roxxx's Avatar
I was going to work this am when my buddy caught me in the back lane askin if i had a moment.
He said he just had his 1992 pulled back from Calgary , It was makin a horrible noise coming from back of the motor....
we went over to have a look . I told him more than likely flex plate cracked no biggy .
200 k no tweaks pump is stock , injectors we think are stock
well as of tonight not to sure whats going on, the oil is down no idea were it went. there is none in the rad or the over flow the oil has no water in it, or Fuel . it is blowing white to chilly to pull head I didn't look to see how much blow by there is but it is making a horrible rattle
Oh and oil pressure is fine ???? and no leaks and didnt seem like it was burning oil
Old Oct 29, 2010 | 08:05 AM
Mike Holmen's Avatar
The Guru
Roxxx Is it an auto or stick? It would be difficult to see the flex plate until you remove the transmission. I have a spare head available for that engine.
Old Oct 29, 2010 | 09:38 AM
roxxx's Avatar
Its an an auto mike
Old Oct 29, 2010 | 11:01 AM
Lil Dog's Avatar
Hard to tell from this story. All the smoke could just be timing, but they don't slip with the VE pump.
Old Oct 29, 2010 | 01:01 PM
cLAYH's Avatar
Pull the valve cover and watch the valves while its running. May have dropped a valve. Onl 10min to get the valve cover off.
Old Oct 29, 2010 | 03:06 PM
The Guru
Good idea Clayh, can't hurt anything now. There are six valve covers, one for each cylinder.
Old Oct 29, 2010 | 03:41 PM
cLAYH's Avatar
Ahh yes. individual covers on those 1st gens. Its been awhile since I had my old '91. So 20 min then?
For the record when the flex plate broke on my '91 I had NO warning or strange noise. I had JUST finished a 2 week trip to Alaska with it and back and the NEXT weekend the flepalte let go. Tore the center out of it. It was turned up but all I was hauling was a 10ft slide in camper.
Another vehicle I worked on(1992 Jeep Cherokee with an inline 6cylinder) came in to me with a BAD bottom end knock. I told the owner the motor was screwed and he replied, "I JUST had new tranny put into it!"
DING! DING! Warning bells went off in my head. A quick look at the convertor bolts found them loose with no locktite! Pulled, cleaned and locktited each one and the owner left my house MUCH happier and relieved.
Old Oct 30, 2010 | 08:46 AM
The Guru
Its a pretty common failure. I'm currently working on rebuilding a 02 dodge truck. It has that stock flex plate, been wondering if the 6.7L flexplate will fit, as its a solid piece. I have one just sitting in my garage. Knowing my luck the starter will not work with it.
Been trying to hand bar over the ruined engine, man its one tight piece of junk right now. Might have to borrow Tate's barring tool again. I put in a bolt into the crank front snub (where the harmonic balancer attaches to), I bent the bolt. Probably messed up the crank. Usually you can hand bar them over that way.
I'll take some pictures and do some compare them today
Old Oct 30, 2010 | 08:25 PM
1-5-3-6-2-4's Avatar
I always turn over them with the alternator nut. way easiest. if its that tight though theres no reason to anyways.
Old Oct 30, 2010 | 10:34 PM
roxxx's Avatar
Well looks like the flex plate went catastrophic. lottsa metal not sure how bad. We took the inspection plate off, not good when it has metal shard every where. Had chunks of the adapter plate fall out to plus flex plate teeth
Old Oct 31, 2010 | 11:11 AM
cLAYH's Avatar
Ouch! Sounds like a new flexpalte and TC are needed.
When I did mine I ordered a 2nd gen flex plate from Cummins. They are heavier/thicker than the 1st gen ones. Got the part number from the FAQ on here. Might be able to find a used one as well.
Also an aftermarket TQ on my '92 made a HUGE difference. Almost as much as changing out the turbo exhaust housing did.
Old Oct 31, 2010 | 01:02 PM
roxxx's Avatar
I think he is going to need the motor adapter plate ,just from the look of the shavings it really did a good number I am going to see if i can find him another trans
Old Nov 2, 2010 | 08:25 PM
The Guru
Here are a few pics regarding auto engine/transmission adapter. Ones a 2002 and the other is off a 6.7L
I'll get my other adapter and post them as well. Both of these adpaters fit on the 2nd VP block and the 6.7L
Old Nov 2, 2010 | 10:00 PM
roxxx's Avatar
Ahh And mike reaches into the tickle trunk
Would you Happen to have one that might fit a 1 St Gen Auto? Mike
Old Nov 2, 2010 | 10:26 PM
The Guru
Roxxx, Yes I do, but... I'm using it, sorry buddy. Sorry for being a tease.
I'll grab it and take few pictures showing the differences between all the different years. I have a 2wd VE engine buildup that on going. I'm using a manual shift RE48 on that engine.
I've been meaning on doing some checks on different block designs that I have to see what matches up and/or doesn't.
Been also wanting to see what it would take to throw a P7100 onto a 6.7L
Notice that the stock 6.7L flex plate is a solid piece.
