IC, how much HP loss if a person dosnet run it?
Old Sep 14, 2009 | 07:49 PM
morkable's Avatar
Just running through thoughts in my head... how much on the 1/4 would a person lose by not having the IC
Old Sep 14, 2009 | 07:55 PM
1-5-3-6-2-4's Avatar
If you cool the charge with nitrous. you won;t notice any loss i bet.
Old Sep 14, 2009 | 08:08 PM
Mike Holmen's Avatar
The Guru
I'm with Luke, testing would determine that for sure so you can make that diffinative. I found out on the weekend, you can't run a lifter valve gridle (the plate on the side of the engine) on a CR motor. The block is different, nothing seriously though. Just looking at my parts, the VE block looks the most beefy. The 98 p pump and my 01/02 24V look similar for blocks. Anyways, one day.
Old Sep 14, 2009 | 08:32 PM
dodgediesel's Avatar
Tons of the big boys don't use them. Nitrous and water meth are the way to go it seems with the big big boys..
Old Sep 14, 2009 | 08:51 PM
The Guru
Hard to just use fuel and make the big ponies these days. The drugs are just hard on parts.
Old Sep 14, 2009 | 08:52 PM
morkable's Avatar
Unless I miss my guess, I think I would actually gain by not having it. With the big chargers I dont think that egt's will be an issue, and the weight gain will be significant, and the simplicity of the piping too
Old Sep 14, 2009 | 09:10 PM
The Guru
There are lots of variables like pressure and temperature at the discharge of the turbo. How much spray you use and where you use the spray is also important. It just changes how much air you really have in the intake.
Old Sep 14, 2009 | 09:25 PM
Swamp_Donkey's Avatar
I will be the first vulture to ask if your old intercooler will fit in my 98.....
Old Sep 14, 2009 | 10:26 PM
winkdemon's Avatar
HOLD ON HERE , MAKE SURE YOU SEND INFO ON PM , SO WE DON'T GET IN TROUBLE , SELLING IN THE FORUM
Old Sep 14, 2009 | 11:14 PM
morkable's Avatar
LOL..
Mike, I dont think that the ammount of nitrous will be a problem,, I can add as much as it takes. And I dont need nitrous to be hard on parts ,, LOL
Old Sep 15, 2009 | 02:00 AM
Hahahahahaha!!!!!! Don't forget about me too.....
Old Sep 15, 2009 | 02:51 PM
morkable's Avatar
Ill keep you in mind!! Jamie you running a pressure box on that bad boy?
Old Sep 15, 2009 | 03:26 PM
ccmckee's Avatar
I have a stock IC sitting on my tablesaw. Just changed it out Saturday.
Adam F
Apr 25, 2005 11:46 AM
papaduck
Mar 18, 2004 11:15 PM
blackjack
Dec 22, 2003 06:09 PM
redramnc
Mar 25, 2003 05:37 AM
