HELP - what did i wreck???
Old May 17, 2010 | 11:08 AM
  #46
Mike Holmen's Avatar
The Guru
It was fun watching Fred play with the new to him mach 6'rs. Can't wait till we put some more air to help clearup all that extra fuel. Hard to for me to imagen someone driving those big sticks on only one turbo And I must sit there and watch my pyro as I tow my RV with them, running twins. Jason, thats ok, we will just rig up the ranger for R&D data logging.
Old May 17, 2010 | 06:15 PM
  #47
Doj Dewd's Avatar
hey i'm up for some r&d this weekend for 1 or 2 days. we can use my truck if needed - only problem is - i don't have a hx40 DP yet . . .
Old May 18, 2010 | 09:55 AM
  #48
The Guru
Jason, as I can get you a S362 here in Calgary right away, it can be built your specs. I'm going to get a parts breakdown for the S300's series of turbos so we can design exactly what everyone wants.
I'm going to look into seeing what that S480 can be adjusted to, we have a new secert project on the go,
Old May 18, 2010 | 10:19 AM
  #49
The Guru
I have Tate's old 40 down pipe, if your in a pinch to get her running. I can plant it somewhere for ya. I'm going to the lake this weekend to drink some beer and do some sleep. Man retirement stuff is hard work.
Old May 18, 2010 | 11:44 AM
  #50
Doj Dewd's Avatar
mike -
the turbo from ED has been ordered, a 62/68/14 built and tweaked for my truck/usage/power levels.
it's gonna take a while to get here, so i'm not in a pinch for a DP just yet . . . unless you wanted to do some r&d with my truck before the new turbo arrives.
Old May 18, 2010 | 03:18 PM
  #51
The Guru
Document what you get? I'm curious to how its configured. I working a pretty sweet configuration, Borg Warner just released a new compressor/turbine wheels. I'm putting it onto my truck and see for myself. I have to keep up with you guys some way, some how.
Old May 18, 2010 | 03:56 PM
  #52
Doj Dewd's Avatar
i'll have them send me a spec sheet on it . . . sounds like they use BW products - not sure if it's the new stuff you speak of though . . .
Old May 18, 2010 | 11:05 PM
  #53
The Guru
What sized sticks you going with Jason? I will be around the following weekend if you can wait. I can share some of the build specs that I have in mind for my new turbo. Its abit different than the normal stuff and I want to try something different.
Old May 18, 2010 | 11:10 PM
  #54
Doj Dewd's Avatar
i'm going with mach 2's (105 hp).
i should be able to hold off until then if you want to give me a hand and spill the beans on this new turbo . . .
Old May 18, 2010 | 11:23 PM
  #55
The Guru
Sounds good, I thought you had bigger injectors than that. You'll have lots of room to grow into with that turbo. Fred's running mach 6's on a garrett stage 3
Old May 19, 2010 | 12:16 AM
  #56
Doj Dewd's Avatar
no, nothing bigger yet. maybe one day but not anytime soon. chris at ED said the same thing - some room to go with bigger sticks if needed . . .
how much boost do you expect i'll be able to make if i had all the boxes maxxed out? i'm not gonna' try though - as i don't have studs . . .
Old May 19, 2010 | 07:26 AM
  #57
The Guru
I would guess around 40-55psi of boost, lots of variables.
Old May 19, 2010 | 03:39 PM
  #58
Doj Dewd's Avatar
ok, good to know. i'll limit the gate at 40psi without having studs then.
Old May 23, 2010 | 06:10 PM
  #59
The Guru
Sounds like a plan buddy. I'll have time next weekend. I'll show you the beasty, maybe by next weekend we can get most of the cage welded in.
Old Jun 11, 2010 | 12:22 AM
  #60
Doj Dewd's Avatar
turbo is finally shipping tomorrow. ED was waiting and waiting for some new parts from borg warner. now i have to wait a for a few business days before it finally is in my hot little hands. can't wait - and i think i'll just install the injectors the same day and be done with it, haha, been waiting long enough - I MISS DRIVING MY TRUCK!!!!!!
